oh ok right yea goes to show how little i use it lol, but yea it's whatever speed you're traveling at, but if the speed limit changes it will suggest you to change to that new speed limit. Which is ALSO completely pointless. I don't know who actually drives the speed limit on freeways
That is an option you can turn off in the settings.
Also, lots of people drive the speed limit on freeways. Not me, but lots of people. The reason it makes the suggestion is in case the speed limit has changed significantly. You can also ignore the suggestion, or turn it off, as above.
But Lucid really has to fix the way adaptive cruise sets its initial speed limit, which as @momo3605 nicely points out, requires a series of up motions (or holding it in the up position for a while) and that is truly inelegant. Not sure what the rationale is?
This is precisely the way it works in every single other vehicle except Tesla. Push to activate, push up once to set speed to current speed, and adjust with a rocker switch if you want to. Two button taps if you’re already at speed, which is when you should be turning it on, and the same as every other car.
it's not two button presses. It's two button presses, then pushing up a million times to get to an appropriate cruising speed.
You should not be turning it on before you’re already on the highway and at speed. It is meant to keep you at speed, not get you on the highway in the first place.
How is that more elegant than having it automatically going to +5/+10 speed limit offset and never having to think about it? Many times you merge on the freeway and there may be traffic, but over a longer distance your speed may increase. You can't speed up to 70/75 safely to turn on ACC/HA in these cases.
Because you do have to think about it, as speed limit recognition is inaccurate, even on a Tesla. I have used it - it worked okay, but was imperfect and I often had to adjust it.
In your scenario, yes, you can turn it on at current speed and then simply hold the rocker wheel up until you are at the speed you want. This is not the most common scenario, and UX shouldn’t be designed to the exception, but the rule.
Nope. In a Tesla, you set your cruise speed setting to speed limit with a +5/+10 or percentage based offset from the settings. Then anytime you pull the AP stalk, it turns on autopilot and automatically sets the speed to the current speed limit + your offset setting with one click.
That is only true for Tesla, and as above, speed limit recognition is imperfect.
A request: let’s please keep this thread civil, for everyone involved.
The crux of the disagreement is that you like Tesla’s UX for setting a speed for cruise control better than the “classic.” Many of us, myself included, prefer the “classic” UX, as it is the same as every car except Tesla, and it is muscle memory.
I agree with you that the knobs kinda suck, but I grip it with two fingers (since it’s got a nice texture) and just roll it that way - zero issues, and it only took a few hours to get used to.
It’s okay to disagree - it’s not okay to imply that your idea of how the UX should work is the *obviously better* idea, just because it’s what you like.
In general, let’s try to approach these discussion with curiosity and interest first, not trying to “be right.” That goes for all. Ask more genuinely curious questions.
For example, a good question could have been “I wonder why Lucid decided to go with the classic approach, rather than the Tesla approach - anyone else here like the Tesla approach? Or do people prefer the classic approach? Are there pros/cons I should consider?”
That would have gone much much better than “ugh lucid sucks and I can’t believe they didn’t just do what Tesla does” (I’m paraphrasing, and exaggerating a bit for effect, but you get the idea).
For the record, I would be fine with adding a “speed limit offset” option, but I do not want it to be the default.
We’re all on the same side here - we all just want people to be happy, with their cars and with their lives.
Let’s keep that in mind.
Thanks all
