Published by P3, the GT came out on top. Interesting read for those who are curious about the charging curves and fastest charging in the charging windows 10-80. Full publication of the study here.
I agree Lucid did not need to push the curve to have the fastest charging EV. That said, the flatter curve below 50% SOC is common. If Lucid can flatten the curve without degrading battery life, it would make our cars that much better. I hope that Lucid will do this as they gather more data and history on their batteries.The philosophical difference between Lucid's curve and Kia/Hyundai is pretty striking. Lucid didn't need to push the batteries to achieve a high rate of miles returned per minute of charging. Kia/Hyundai did.
I'm not sure if I follow. The blue Lucid curve in the first graph drops pretty continuously from about 250 as SOC increases down to ~100 kW at about 70%. But you experienced a flat and steady 146 kW until 72% SOC?That charging curve was exactly what I experienced this weekend at a 150kW EA station. At 14% SOC, it was drawing steady 146 until it hit about 72% SOC. Then it dropped fast to about 80 when I stopped. I was charging next to an EQS who started her charge at 21% SOC about 10 min into her charge. My session was 34 min, and she had hit just 71% when I looked over.
It was a 150 kW station so it can put out max 150 even though a few here reported higher. So my charge started at 146 @14% SOC and stayed there until I hit 72%. The remaining 8% to 80% was the only time I saw the drop to 80 kW which is in line with the published curve.I'm not sure if I follow. The blue Lucid curve in the first graph drops pretty continuously from about 250 as SOC increases down to ~100 kW at about 70%. But you experienced a flat and steady 146 kW until 72% SOC?
I think it has more to do with thermal management. I would love for Lucid to match those curves if it can!This is a great study and in line with the chart I saw on my first 350kw charging experience. However, Kia and Porsche have it pushing harder (they must be assuming the battery is not degraded faster). It would be great is Lucid could maintain a 250+ for the first 45 or 50%. By the time I got to 50% Soc it was charging at about 125kw. The chart below is similar.
However, Based on simple math, if lucid stayed at 250 until 45% Soc it would charge to 45% from 5% Soc faster by about only 3 or 4 minutes. I guess if this curve is better for the battery then it is worth it. Do you think Lucid engineers are smarter? Or more conservative?
This. Given all of their experience with BMS for Formula E, I'm more than willing to believe they've seen their motors and batteries ridden harder and faster, and are being conservative for good reason.Lucid has way more experience with BMS than either of these companies. The charging curve makes sense for consumers but not for longevity. I trust them to do what they think is best.
