I had to reconfigure due to losing WiFi connectivity. As
@DeaneG mentioned, reboot the charger, wait for logo LED to go solid and connect to the setup WiFi that will be named the serial number of your charger and the password is the same. Then connect to
http://192.168.5.1 which is basically the web portal. Default password is the serial number as well. In there you can change the WiFi settings for a more permanent arrangement by connecting to guest network as mentioned - any network with an IP range other than 192.168.1.X.
