I had an incident today and want to see if anyone else has experienced this. I was in my driveway about to pull out (I had parked with the trunk facing a pillar in my driveway). I put the car in Drive and pressed the accelerator. The car started moving backwards. I checked that I was in Drive again and same result. In getting in the car, the mobile key did not open the doors as they usually do, so I had to use the key card. Once I was in, it recognized me as the user. I let the car sit for 30 mins while I ran the errand I needed to do and tried again. Same result. By this point, the 4+ feet to the pillar had become 20 inches. So I called customer service. They sent the tow truck. The tow truck driver tried the same thing, and it also drove in reverse. Then he tried a second time and was able to drive forward. Feeling pretty stupid at this point and I was going to cancel the service appointment but he convinced me that I should let the service center check it out and make sure everything is ok. He also told me that he had towed another Lucid with this problem. Has anyone on the Forum heard about this or experienced it?
