Amazon Alexa skills with Lucid motors
I can’t find Lucid Motors in the Skills tab in my Alexa app. Am I missing something or perhaps it’s not available in Canada? Alexa is connected to my car (I can ask generic questions like “what is the weather today”) but it won’t respond to any of the skills it is supposed to such as “Alexa, lock my doors.”
it's dumb alexa. For some reason, the in-car alexa systems don't work the same way an echo device does. It does not work with the majority of smart home commands.
The problem is that you need to be very specific with the commands or its effectively useless. If you go to the Alexa integration area in the settings of your Lucid I believe it has the list of commands you can use but from past experience you need to say them verbatim for Alexa to understand. It's too dumb to figure out when you deviate away.
The only command I use in my car with Alexa is "Alexa, open the garage door" everything else is just quicker for me to do manually vs trying to remember the exact words.
I have very few problems with Alexa in the car seems to work for most things although oddly enough it doesn't recognize SirusXM as an authorized device (weird). The Alexa Lucid Skill however (where you tell your home Echo's to "Lock the car doors" or some such) simply doesn't work for me. When I try it, I get all sorts of less-than-helpful information about Lucid Motors. I tried various combinations/re-linking the skill/etc for about 30 min then I felt I had better things to do. If anyone has the skill working where it interacts with your car and wants to tell me where I messed up, it would be most appreciated!
The skill in Alexa isn’t working for me right now??
It did work a couple weeks ago?
Very limited functionality. The only thing I could her to tell me was the battery percentage.
The ones I use most or "Alexa, call xxxx" or "Alexa, text xxxx" and "Alexa, navigate to xxxxx" I've used it to set temperature and stuff like that, but like you I often forget the exact words and doing it manually is fast enough.
Does anyone have a LIST of ALL the known Alexa commands?
I know you can see SOME of the available commands in the setting menu.
I just enabled the skill but it doesn't work at all.
The skill isn't working for me today either.
Enabled it in July and it worked, with very limited value.
"Alexa what is the mileage on my Lucid" - 410 Miles.​
"Alexa are the doors on my Lucid locked" - The doors on Lucid are locked.​
I don't think the "Skill" is valuable.
I think someone else said you could "Precondition" with Alexa which turns on the A/C. (Confusing as it has nothing to do with Preconditioning Battery).
My question above was relating to Alexa in the Car, which seems very Valuable.
"Alexa, Set the Temperature to 71 degrees"​
What else are people finding valuable?
Not working anymore? Lucid?
Alexa works perfectly on my Sapphire.
The proper command is
"Alexa, boost my power output from 1234 hp to 1520 hp"
It works flawlessly every time.
you don't need alexa for that. just find a NOS sticker... done!
