- Jun 4, 2022
- Scroggins, TX
- RX350, IB/Tahoe Touring
- 6EDNB149
Excellent points! In such a software intensive "system" as the Air, it makes me wonder how detailed of software engineering analyses were performed give the time pressure Lucid was under to start deliveries. The interaction between the hardware subsystems and the software can cause all types of intermittent performance gremlins. This can be caused by hardware failures in functional subsystems or signal related timing issues driven by software communication. The aerospace industry typically performs a functional Failure Modes, Effects, And Criticality Analysis (FMECA) on their design topology. Essentially, if you lose a function due to a hardware failure, what is the effect and criticality of the resulting functionality loss. In the case of the Air being so software intensive, I would also hope that the Lucid Software Engineering team has done an extensive functional Sneak Circuit Analysis (SCA). A SCA assumes the hardware is functional with no hardware failures (reasonable assumption for a new Air) but that unintentional (and usually undesired) signals are being energized at the wrong time. This is often signal timing related or functional states not being reset properly. These Sneak Circuits often manifest themselves as intermittent unexpected functional performance, i.e. one seemingly unrelated subsystem left in the wrong state at the wrong time can possibly impact another subsystem... Those gremlins can be difficult to trace to root cause, and one can only hope that with time the Software Engineering team can leverage their FMECA and SCA to deliver a much more robust software system design... The SCA is usually performed under the assumption of having a robust software design that anticipates and accommodates user actions in satisfied software design requirements. Obviously the consensus of this Forum indicates the Air has not yet reached that level of software design maturity... Personally I have to believe they will be able to resolve these issues before my Touring Stealth gets built next year!That’s possible, but it makes me wonder then why are things usually cured by a reboot? Of course @hmp10 couldn’t troubleshoot the AC cuz his pilot panel went out. Other solutions could be to park and lock the car then try and remote set the climate system from the phone app. I just think if it was a hardware/wiring problem then it would just fail and that would be that. Doesn’t make sense to me that resetting the software would somehow change the electrical layout, although software can dictate open/closed circuits. I’m more suspicious that the underlying software which controls how power is distributed to various modules in the vehicle is bad. Given they did a recall on every car for a wiring harness issue that affected almost no vehicles, I’d think if this was a wiring problem we’d have seen another recall.
