- Nov 14, 2021
- Dream P
- Air DE Number
- 33
- Gravity DE Number
- 33
- R0YBCKIJ
Thanks to our wonderful members for compiling the lists of checklists for delivery, particularly @SaratogaLefty with his post HERE and subsequently @zkhan2 with his list HERE. I'm going to post the most recent checklist as some of the earlier items no longer apply.
After the post is an attached checklist you can print.
OUTSIDE CAR CHECK LIST
- Check panel/door gaps
- Trunk alignment and clearance at bottom – Sharp Edges? Marks?
- Frunk alignment and gap
- Rear door seals
- Check all exterior lighting
- Make sure all door handles respond to pushing/pulling
- Approaching with paired mobile key causes vehicle to unlock (various angles).
- Unlock vehicle with non-paired key and make sure it recognizes main driver's face
- License Plate attachment – proper screws and tightness
- Alignment of glass
- Quality of glass
- Scratches on glass?
- Look for paint swirl marks and dust divots
- Look for paint pig tailing (happens from sanding out contaminants)
- Look for polishing compound (i.e. wax) on trim edges
- Look for glue on trim
- Make sure trim is flush to body
- Look for paint overspray on trim (usually very small spots)
- Make sure trim is attached to wheel well
- Check door, frunk, trunk openings for places where repaint overspray got under tape
- Look for taped edges that are sharp on repaints
- See if door cross/mid trim (between widow and door panel) is not loose.
- Open/Close “Frunk” multiple times to ensure smooth operation using Fob and also from inside the car.
- Trunk and frunk rubber gasket glue and alignment
- Full Test Drive with Rep before leaving Center
- Setup Bluetooth with Phone
- Facial Recognition Profile Setup
- Setup Alexa Voice Command
- Login to Tidal
- Where is my Sirius/XM radio number
- Instructions for Hard and Soft Resets
- Reboot sequences: power the car down and back up to check screen loading
- Instructions for Setting Up Homelink
- Mobile Key setup on Lucid App:
- Key Card vs Key Fob vs Mobile App (iPhone) for Locking/Unlocking (all on person)
- Setup second driver profile
- What does Valet need -Key fob or Key card?
- Setting Up Lucid App and proper charging procedure with Electrify America (EA Account Setup)
- Navigation Setup
- Set Upper Nav Screen to 3D and lower to 2D
- Setting up Profiles for Key Fob and Mobile Key
- Window shades operation fully functional
- Check Surround View for Parking Assistance
- Check Both Front Seats Heat and Cool Ventilation
- Check Seatbelt Retraction and Height Adjustment - All Seats
- Check Air Vents Adjustability
- Check Windshield Wipers - Proper Seating and Operation
- Adjust the Side Bolsters all the way in and all the way out to see if any “popping” noise
- Massage Seats – Try the Deep Setting on Level 1, 2, and 3 to see if any difference?
- Do all the vents blow air, and can all of them be adjusted – front and rear?
- Do all seat belts work?
- Do all window switches work?
- Check operation of all inside door latches.
- Check all interior, puddle, glove box, storage bin, reading, frunk, trunk lights.
- Headrest adjustment.
- Lumbar adjustment.
- Glovebox
- Window shades/visors
- Door lock and unlock from inside – all doors
- Auto headlights
- Auto high beam
- Mirror dimming
- Adjusting interior light levels
