- Oct 4, 2022
- AGT
Mine have remained so farInstalling now. Hopefully the favorites disappearing \ reappearing randomly is fixed. Alexa is done for me, I turned that ***** off 2 updates ago![]()
Mine definitely took longer than 10-15 min. I’d say about 40 min or so.Thank you. I received a message back saying they confirmed I am running on .47. They mentioned having a glitch in the software causing the version numbers to not be updated in the vehicle.
The update certainly didn't take 50 minutes. Guessing maybe 10-15?
My mobile key is WAY more reliable now...must be a software improvement thereQuick updates I noticed.
There are things being added that aren't directly prevalent or obvious in the notes.
Noticed after my drive yesterday that with the steering wheel being in a up position, it now tells me that the camera cannot monitor my eyes or see my face because "camera is blocked". And then I get a yellow eye 👁🗨 logo with a / through it
I also noticed my mobile key is WAY more reliable lately. Coincidence? Idk
Would like to hear your guys' thoughts if you've noticed anything lately
Play David Bowie was literally the first question I asked Alexa today!It’s done updating and Alexa does seem to be better at first blush. Only weird thing is that if I say something like: “Alexa, play songs by David Bowie, it does exactly what I ask for, and if I skip to the end of each song it comes up with another by Bowie. All good. Then if I open Tidal (which is the app
I set Alexa to use), and look at the queue, it bears no resemblance to the song list I am playing. It’s almost as if Alexa launches her own instance of Tidal, that is not connected to the app in the car UI.
Got the same alert after raising the wheel. I find HA easier with a raised wheel, since I can sort of hang down on the lower part of the wheel with two fingers. Not a fan of this alert.Noticed after my drive yesterday that with the steering wheel being in a up position, it now tells me that the camera cannot monitor my eyes or see my face because "camera is blocked". And then I get a yellow eye 👁🗨 logo with a / through it
If you text customer care, they’ll re-push it.Got "Unable to Install Update" warning; "We will inform you when a new update is available." First time an update has failed for me.
Had the same issue before, this was the update team's suggestions. I would follow it!Got "Unable to Install Update" warning; "We will inform you when a new update is available." First time an update has failed for me.
Glad I'm not the only one.My mobile key is WAY more reliable now...must be a software improvement there
I think it's a CYA thing. They can claim in the event of an accident that they're not aware you were paying attention because you had the camera blocked despite the warnings.Got the same alert after raising the wheel. I find HA easier with a raised wheel, since I can sort of hang down on the lower part of the wheel with two fingers. Not a fan of this alert.
Alexa is playing from it’s own Tidal instance (with the credentials you provided in the Alexa app) and in theory can stream in UHD which literally sits between Master quality (up to 24 bit/384khz) and hi-fi quality (16bit/44khz) at roughy 24bit/192khz. Sadly Alexa does not provide any visible distinction for track quality and as such unlike your curated playlist from the tidal app on your phone which is matched by Tidal on Lucid software, with Alexa you have no certainty of quality of the chosen track played by Alexa.It’s done updating and Alexa does seem to be better at first blush. Only weird thing is that if I say something like: “Alexa, play songs by David Bowie, it does exactly what I ask for, and if I skip to the end of each song it comes up with another by Bowie. All good. Then if I open Tidal (which is the app
