- Nov 22, 2021
- El Dorado Hills, CA
- ‘04 Prius, ‘98 MB SLK230
What are the dimensions of a compatible after-market 19” wheel?
That's the problem so far. HRE makes them, but a set will cost $10k minimum.What are the dimensions of a compatible after-market 19” wheel?
I had the same problem but chose the 19." Not just because of the Pirelli tires on the 21's but the fact that wheels are cast, not forged so are much more susceptible to road damage with the low aspect ratio tires.
Many vendors make wheels that will fit the Air. You can order 19" "forged" Velox via Costco for $470 per wheel. Oddly the photo is of a Maserati. https://www.veloxwheel.com/order/select-wheel/?vehicle=52998That's the problem so far. HRE makes them, but a set will cost $10k minimum.
Not sure I’d feel comfortable throwing the 5000lb lucid into a corner at speed on those wheelsMany vendors make wheels that will fit the Air. You can order 19" "forged" Velox via Costco for $470 per wheel. Oddly the photo is of a Maserati. https://www.veloxwheel.com/order/select-wheel/?vehicle=52998
That's why the "forged" was in quotes. But there are and will be many, many choices for wheels available. That said, I wish I could have Lucid's 20's in an amount of time which suits my patience.Not sure I’d feel comfortable throwing the 5000lb lucid into a corner at speed on those wheels![]()
20" not available till Dec or so.But what about 19 vs 20???
As long as it doesn't drop below 40 degrees I think summer tires are mostly fine.Anyone know if summer tires (e.g. the 20 inchers) would be an issue to use year-round in the Bay Area, specifically SF? Is it asking for trouble?
You’d be fine. The only thing to watch out for is potholes on the 21s.Anyone know if summer tires (e.g. the 20 inchers) would be an issue to use year-round in the Bay Area, specifically SF? Is it asking for trouble?
If it gets below 40 like @hydbob said the tires get brittle hard and traction is an issue. It would be difficult if you had to do those steep hills, but if you are flat you could be ok being cautious and defensive driving. I had summer tires on a Fisker Karma in Atlanta and it was ok on flat roads, but you could tell the tires just could not perform well...I switched to AS. If you can switch tires out, great...if you want one tire to rule them all AS.Anyone know if summer tires (e.g. the 20 inchers) would be an issue to use year-round in the Bay Area, specifically SF? Is it asking for trouble?
I am sure you can find them. They might not be the exact size Lucid uses. You can go +10 or -10 on width provided the wheel well has clearance.Anyone knows if there will be 21” all season tires option eventually? I thought I read that somewhere in the forum, but I couldn’t find it.
My DA told me previously that they are looking at offering a 21" all season at some point. When that would be, your guess is as good as mine...Anyone knows if there will be 21” all season tires option eventually? I thought I read that somewhere in the forum, but I couldn’t find it.
There are no officially approved 21" AS tires yet, but Tire Rack has these 2 options for the Lucid 21s:Anyone knows if there will be 21” all season tires option eventually? I thought I read that somewhere in the forum, but I couldn’t find it.
Is it okay to ride on an unpaved path with 21"? In the use cases of going to a trail head in some places there will be unpaved roads. hence asking.You’d be fine. The only thing to watch out for is potholes on the 21s.
