- Feb 13, 2022
- Scottsdale, AZ
- GT
- IDLI9CO7
FWIW, off the cuff comment from a techs supervisor at the SC was that he saw no problem with the smaller wheels on the rear. But he wasn't 100% sure.Here are the specs for front and rear. Only
Looked up the 20/21 on TireRack.com. A little bit different outside diameters. Not sure if this is acceptable:
This front/rear set fits your 2025 Lucid Gravity 265/50-20F 285/45-21R.
- Size:265/50R20 (Front)
- Service Description:111Y
- Load Range XL
- Max. Load= 2,403 lbs
- Max. psi= 50 psi
- LM1 Lucid, soundabsorber
- Eco Focus:EV Eco Focus tire technology emphasizes low rolling resistance, resulting in better fuel economy.
- Noise Reduction Technology
- Electric Vehicle Tuned
- UTQG:600 A A UTQG
- Max. Load:2,403 lbs
- Max. Inflation Pressure:50 psi
- Tread Depth:9.5/32"
- Tire Weight:36 lbs
- Rim Width Range:7.5-9.5"
- Meas. Rim Width:8.5"
- Sect. Width:10.9"
- Tread Width:8.4"
- Overall Diam.:30.2"
- Revs. Per Mile:687
- Country of Origin*:KR
- Size:285/45R21 (Rear)
- Service Description:113Y
- Load Range: XL
- Max. Load= 2,535 lbs
Max. psi= 50 psi- LM1 Lucid, soundabsorber
- UTQG:600 A A UTQG
- Max. Load:2,535 lbs
- Rim Width Range:9-10.5"
- Meas. Rim Width:9.5"
- Sect. Width:11"
- Tread Width:8.6"
- Overall Diam.:30.9"
- Revs. Per Mile:673
