- Mar 31, 2025
- Air GT
My case appears to be different from those here in that the signal records properly, but then Homelink fails its tests.
I got my new Air GT yesterday. Yay. I have tried the following to get Homelink to work:
--I move the car where the front is under the receiver and also just in front of the receiver. No difference.
--Every press of my remote operates the door without fail (and I have 2 remotes, tried them both, they work fine, Lucid recognizes a signal from either one)
Any ideas people? I fear that customer service number will be of no further use in this issue.
- Simply followed instructions. The car honks/flashes lights and records the signal. Then it fails to communicate with the garage receiver (which is less than 10 feet away). Repeated this 4 times. Same fail.
- Called the Lucid customer service number. Guy said try the reset (#3), and if that doesn't work he can't help.
- Did a soft reset (X + mic + brake). Then repeated above sequence. Records the signal, fails to communicate with receiver. Just as every time defore.
