msaunders9430
- May 16, 2024
I was wondering the same.Looks like a door guide, my bet is to improve crash ratings
Is it part of the soft-close feature?
Those are usually part of the lock mechanism so I think it’s just to keep the door in place during impact so it doesn’t shift under load.I was wondering the same.
The configurator says "The adaptive air suspension offers a balanced 7.0-inch ride height, with the flexibility to raise up to 9.0 inches for increased clearance or lower to 5.0 inches for improved aerodynamics and efficiency". So, with five ride heights, it's manually adjustable in 1-inch increments between 5 and 9 inches, would be my understanding.There are five heights. Smooth and Swift default to Standard, and Sprint defaults to Low.
The heights are: Highest, High, Standard, Low, Lowest.
The OOS video had it in “Lowest”
Uh-oh. What!?I concede that I have no idea what I’m talking about! All I know is it was fun to drive and it looks amazing! The car has magnificent curb appeal, and definitely has all the tenants an SUV.
I don't think it is actually 1-inch increments, but I don't know for certain.The configurator says "The adaptive air suspension offers a balanced 7.0-inch ride height, with the flexibility to raise up to 9.0 inches for increased clearance or lower to 5.0 inches for improved aerodynamics and efficiency". So, with five ride heights, it's manually adjustable in 1-inch increments between 5 and 9 inches, would be my understanding.
I recall reading a 2023 press release:
With the Gravity SUV, performance extends beyond paved roads as Lucid introduces Zero Gravity, an enhanced optional air suspension package that automatically adapts to various terrain needs, ensuring a smooth and comfortable ride on any surface. Manual adjustments also offer the ability to raise Gravity to maximize off-road capability or lower it to maximize performance and range.
Three drive modes and five ride heights.
The drive modes are configured to function within a certain range of ride height.
Maybe something like this?
- Highest - 9"
- High - 8"
- Standard - 7" (Smooth and Swift drive modes)
- Low - 6" (Spring mode)
- Lowest - 5"
The driver can manually adjust to ride heights such as highest, high, and lowest that are not available in a drive mode?
I think you are right about it having something to do with locking/keeping the door in place as one can see at the bottom right edge of the picture that there appears to be part of a matching feature on the inside of the door that could insert into that slot in the body. (With some plastic/rubber to reduce rattling sounds inserted)Looks like a door guide, my bet is to improve crash ratings
It looks like that bar on the door at the lower right of the image slides into it.I have a Gravity design question. What is the purpose of this slot behind the rear door? I've never seen that on a vehicle before.
Saw that.It looks like that bar on the door at the lower right of the image slides into it.
Yeah I've seen a similar design on Subarus. Probably to keep door from collapsing inward during a side impact.I think you are right about it having something to do with locking/keeping the door in place as one can see at the bottom right edge of the picture that there appears to be part of a matching feature on the inside of the door that could insert into that slot in the body. (With some plastic/rubber to reduce rattling sounds inserted)
"Leaking bag mode?"
Do you know what are the limitations on height vs driving mode combination?There are five heights. Smooth and Swift default to Standard, and Sprint defaults to Low.
Uh-oh. What!?
You drove it!?
Production model?
Spill the beans man!
Any feedback on software functionality?
They are completely independent.Do you know what are the limitations on height vs driving mode combination?
For example, is sprint limited to low and lowest heights only?
Can smooth be combined with low/lowest, or it’ll limit the range of vibration absorption for smooth to act properly?
Pretty sure as the speeds climb above 120 it will force the suspension down regardless of how you feel.They are completely independent.
Yes, I believe it does lower at highway speeds as well. But at low speeds you can drive it in any height/mode.Pretty sure as the speeds climb above 120 it will force the suspension down regardless of how you feel.
120 being a random point, could happen earlier or later.
“Lucid Gravity: The SUV that turns physics into poetry.”I have a Gravity design question. What is the purpose of this slot behind the rear door? I've never seen that on a vehicle before.
Yep, it must have something to do with an impact locking mechanism:
It seems to be a late addition to the car. Here's a photo of the Gravity I saw in the Miami Worldcenter Design Studio a couple of months ago, with no such mechanism present:
I wonder if crash testing showed the need for such a mechanism?
When I drove the PRODUCTION GRAVITY on Saturday, I noticed this interesting piece of engineering and I inquired further. It’s the only one I’m aware of that uses the “hand in glove”, “slot & hook“ design to improve rear passenger survivability!
I know this is a bit wonky for most but is a testament to #CompromiseNothing attitude!
Good eye @Amster for seeing the same thing! I see somebody else above mentioned Subaru, but was wondering if that is a production model picture?
Turns out there are a number of cars that have had this feature. 2018 Porsche 911, 2010 Subaru, and the 2024 Tesla Model 3!
