Typical Level-2 charging sound?
Little629
2025 pure
Using a Tesla wall charger with a Tesla Tap adapter. Does this sound normal?
  • IMG_9282.mov
    13.9 MB
Interestingly, I heard a similar sound this morning and it was the first time I noticed that sound. I use the LCHS on a 100a circuit. Curious to hear other views.
My Air has produced that exact sound during 40A charging ever since it came back from its RDU-replacement service (~1600 miles). Prior to that, I never heard any sounds from the rear of the car during charging; only the cooling fans. Nowadays I hear that odd noise from the left-rear, and a different odd noise from the right-rear (rapid clicking sound) for less than 20 seconds after charging begins. The charging process itself hasn't had any faults/issues, so I haven't contacted service about it.
Someone on Reddit commented on my post noting it sounded like the coolant pump had air trapped inside. To my ear, that certainly sounds possible. Since then I haven’t heard the noise again. Worth noting, I launched the car twice probably 5 minutes before this video was recorded so maybe that has something to do with it.
Had my AT for almost a year and I heard something similar for the first and only time two days ago after plugging in. At the time the battery had the cold energy reduced message and I put it down to that. Didn’t do it yesterday when I charged.
I had a txt exchange with my Service Advisor. He hypothesized the same. “Might be the coolant pump. Those things make a lot of of sounds”. Though I couldn’t reproduce it either, he said that if it’s a real issue it would throw a code.
I’ve also tried a few times and couldn’t get it to happen again.
It’s an incredible coincidence that it happened to three of us? Or it happens a lot more and folks don’t make much of it?
Fingers crossed!
