Using The Valet Key Card
I may be late to the party here but I have confirmed there is a way to start the Lucid Air with only the valet key card.
- Unlock/Lock: Tap the card on the B pillar just above the camera.
- Start/Drive: Bypass the PIN by tapping the card to the right of the center microphone array (See picture)
This allows the valet, car wash, or other guests to use the car without the key fob or your PIN
@experiment458 - If I use this method, will it effectively unlock all of the instrumentation, allowing changes to be made to the various configurations, etc.? And if so, is there a way then to link a valet card with a specific profile, to at least avoid unwanted changes to my profile?
The valet card cannot be linked to a profile, only the fobs and mobile keys can be linked to a profile.
My question is how would a valet or car wash person know how to do that?
The way it works is that you give the valet the card, and ask the valet if they know how it works. They say yes. Then when you pick up the car, the valet goes to get it, walks back, and asks you why the car won't start. I learned all this when the Model 3 first came out.
May I know how to relative this card to one exsiting profile ?
Or the valet you gave it to is on a break or has left. And the new valet is looking for a key or a fob, and has no idea what to do with a card. I just give them the fob.
It's in the user manual and it came up in another thread about valet access and pin codes.
While this work around works…. It is not documented in the latest online manual. Great to know especially when you forget your own pin. Is there any other uses for the pin?
Thank you for this thread. Yeah, super non-obvious and I was going crazy and thinking this can't be real. And abs-effing-lutely, using the valet key should put the card in Valet mode. Valet mode should lock the glovebox and trunk and give the car maybe a 2 mi radius that it can be driven in. Because you know -- Ferris Bueller.
But the card is a key. What’s the difference handing them a key fob? Can’t expect them to remember a PIN
If the fob dies, I'd be more worried. But also it was shown to me that the fob does work even when dead. Just need to hold it to the b pillar and push door handles simultaneously. I have a video demonstrating a year ago on this forum.
