- Nov 22, 2021
- El Dorado Hills, CA
- ‘04 Prius, ‘98 MB SLK230
Does anyone know when LIDAR will be implemented in DreamDrive Pro?
Same. It will show an orange depth wave on surround camera with displayed “inches” as I approach and then red with “BRAKE” and will stop the car.My car definitely brakes when approaching stationary objects. Make sure the early collision system is on.
Yes, my early collision system is on, but when approaching stopped traffic at over 35mph, I would rear end the car in front of me, if I wait until the brake warning for it to stop. The system also does not ‘see’ traffic if there is a bend in the road. There are too many edge cases to enumerate here. Let’s just say it works much worst than the Tesla system, which has no LIDAR.My car definitely brakes when approaching stationary objects. Make sure the early collision system is on.
This is using the ultrasonic sensors. The topic is regarding LIDAR, which is used to maintain safe distance to objects while driving on the road.Same. It will show an orange depth wave on surround camera with displayed “inches” as I approach and then red with “BRAKE” and will stop the car.
I have had the same issue since ACC was turned on and I reported it to Lucid. Only happens when all of the traffic in front is stopped. My two other cars with ACC do not have this issue, and neither has LIDAR.Yes, my early collision system is on, but when approaching stopped traffic at over 35mph, I would rear end the car in front of me, if I wait until the brake warning for it to stop. The system also does not ‘see’ traffic if there is a bend in the road. There are too many edge cases to enumerate here. Let’s just say it works much worst than the Tesla system, which has no LIDAR.
So your car will continue to drive on ACC directly into a stopped car in front of you? Yikes. The ACC on mine works flawlessly so far. Even when I get cut off suddenly within inches, the car smoothly handles the interaction.I have had the same issue since ACC was turned on and I reported it to Lucid. Only happens when all of the traffic in front is stopped. My two other cars with ACC do not have this issue, and neither has LIDAR.
Here are some Warnings from the Owner's Manual. As you can see, the system effectively does not work (especially see the 6mph limitation):So your car will continue to drive on ACC directly into a stopped car in front of you? Yikes. The ACC on mine works flawlessly so far. Even when I get cut off suddenly within inches, the car smoothly handles the interaction.
- WARNING: Adaptive Cruise Control is designed for your driving comfort and convenience and is not a collision warning or avoidance system. It is your responsibility to stay alert, drive safely, and be in control of the vehicle at all times. Never depend on Adaptive Cruise Control to adequately slow down the vehicle. Watch the road in front of you and be prepared to take corrective action at all times. Failure to do so can result in serious injury or death.
- WARNING: Never depend on Adaptive Cruise Control to brake for pedestrians, animals, or other objects. Always watch the road and be prepared to take corrective action. Failure to do so can result in serious injury or death.
- WARNING: Do not use Adaptive Cruise Control on city streets or on roads where traffic conditions are constantly changing.
- WARNING: Adaptive Cruise Control may not detect or brake for
narrow vehicles such as bicycles or motorcycles.- WARNING: Adaptive Cruise Control may not detect stationary or slow moving vehicles below 6 mph (10 km/h).
- WARNING: Do not use Adaptive Cruise Control on winding roads with sharp curves, on icy or slippery road surfaces, or when weather conditions (e.g., heavy rain, snow, or fog) make it inappropriate to drive at a consistent speed. Adaptive Cruise Control does not adapt driving speed based on road and driving conditions.
- WARNING: Turn Adaptive Cruise Control off temporarily when driving in areas where you must reduce speed (e.g., turn lanes, entering and exiting highways, or construction zones). This prevents the vehicle from accelerating to the stored speed in such situations.
[ADAS pg 98]
The issue I have had is when ALL of the cars in front of me are stopped and no traffic around me. My guess is that the DE systems have trouble getting a motion reference from the stationary cars in front.So your car will continue to drive on ACC directly into a stopped car in front of you? Yikes. The ACC on mine works flawlessly so far. Even when I get cut off suddenly within inches, the car smoothly handles the interaction.
FWIW, my Model S would NOT detect cars if they had not seen them moving and they were stationary (e.g. cresting a hill into stopped traffic). It needed the objects to be moving or have been recently moving. I believe these systems work on an object's change of position and not necessarily the object itself. I would have never trusted my Tesla to bring me from higher speeds to a stop behind objects that were stationary. My current experience with the Lucid is that the ACC works as good or better than the Model S. Way less over-braking when someone cuts you off, etc. However, I never expected it to bring me from speed to a stop behind stationary objects that it hadn't seen moving.The issue I have had is when ALL of the cars in front of me are stopped and no traffic around me. My guess is that the DE systems have trouble getting a motion reference from the stationary cars in front.
I have not tried to repeat this problem with 1.2.1 but will. I HAVE verified that the three other vehicles we have with ACC do not have this fault.
My only ACC experience is with Ford and Mercedes.FWIW, my Model S would NOT detect cars if they had not seen them moving and they were stationary (e.g. cresting a hill into stopped traffic). It needed the objects to be moving or have been recently moving. I believe these systems work on an object's change of position and not necessarily the object itself. I would have never trusted my Tesla to bring me from higher speeds to a stop behind objects that were stationary. My current experience with the Lucid is that the ACC works as good or better than the Model S. Way less over-braking when someone cuts you off, etc. However, I never expected it to bring me from speed to a stop behind stationary objects that it hadn't se
Completely agree. Lidar should (eventually) make the Lucid's performance and safety better than any other car. Unfortunately, we are not there yet which is disappointing.I have bitched and complained about the ACC and almost all of the software in my car, BUT, I truly hope that Lucid's software group gets their act together and produces world class systems! The hardware in the car is great, just needs great software.
My ACC on my BMW PHEV has been totally reliable even without lidar. It may not be a "safety feature" but it becomes a safety anti-feature once one has it and starts to rely on it.While my ACC did not auto-brake for a car stopped in front of me it did warn me, got the red light on the dash and the camera view automatically came up on the screen so I could see distance to the car. It may well have auto-braked (my Mercedes did this well, my wife’s Subaru with EyeSight does it way over aggressively) but I intervened first. I have had the Lucid successfully auto-brake for rear cross-traffic, but it did miss one front cross traffic alert, I think due to a large SUV that was illegally parked too close to an intersection which blocked my view of incoming left cross-traffic.
They need to call MicroVision and talk to THEM About REAL LiDar. Everything else is still Pedestrian. MVIS will have one ready byQ-3. They just speed tested it at Highways speeds of 80MPH. They have some nice Videos on their Website. I was about to post a new discussion and I found this.While my ACC did not auto-brake for a car stopped in front of me it did warn me, got the red light on the dash and the camera view automatically came up on the screen so I could see distance to the car. It may well have auto-braked (my Mercedes did this well, my wife’s Subaru with EyeSight does it way over aggressively) but I intervened first. I have had the Lucid successfully auto-brake for rear cross-traffic, but it did miss one front cross traffic alert, I think due to a large SUV that was illegally parked too close to an intersection which blocked my view of incoming left cross-traffic.
The ACC on the Front for me is pretty good on my QX-80 but it has no LiDar. NO-ONE HAS LIDAR in their cars today Except maybe Lucid and I believe its from Cepton and pretty pedestrian and archaic.My only ACC experience is with Ford and Mercedes.
