1) Airs cannot charge at superchargers yet, but will be able to in Q2.
2) The max rate will be 50kW on any of the existing superchargers.
3) Eventually, Tesla claims it will build 1000V cabinets to power 1000V chargers, at which point the Air will be able to achieve the full 350kW (or 250kW for the lower trims). These cabinets do not exist in the US yet as far as we know.
4) The “Wunderbox” (spelled this way, I bet, because Eric Bach is German, and I can pretty much guarantee he named it haha) is the Air’s built-in battery charging system. It is what automatically recognizes the Air and station, adjust incoming voltage, and boost voltage if needed. There’s a great video about the Wunderbox, explained by Eric himself, here:
5) When the Air was designed, it was made for the “future”; nobody expected us to go *back* to the old lower-voltage chargers. EA, EVGo, and everyone else had already moved on to 800-1000V chargers. Only one company hadn’t: Tesla. Then, there was this whole switch from CCS to NACS, which meant Tesla was now the widest charging network in town, and
they used older and lower-voltage stations/cabinets. This unfortunately meant that Lucid’s assumptions about the future were incorrect, and thus it is limited to 50kW on the lower-voltage stations at Tesla.
6) The hope is that Tesla does actually build out the 1000V stations/cabinets, and this is no longer a problem. In that sense, the ball is in Tesla’s court to join the rest of us in the “future.”
7) The Cybertruck runs on an 800V architecture, just like the Air, so Tesla has at least *some* incentive to actually build out the 1000V cabinets.
Side note: this isn’t an issue for Gravity, as that was designed and build after the NACS switchover, so it handles the backwards compatibility more gracefully and will charge at maximum speeds wherever and however you get it plugged in.
