- Aug 15, 2022
- Baltimore, MD
- QG/SC AT, MB GLE 350
How long does the 12,000 mile service take? If I drive to Tyson’s and wait, I’d like to have an idea how long to expect.
Ask them. Your best source.How long does the 12,000 mile service take? If I drive to Tyson’s and wait, I’d like to have an idea how long to expect.
My visor batteries were dead in just a little over a year and we rarely use them - perhaps 2 or three times before the batteries were done.I read somewhere else that the sun visor batteries only needed replacing every three years. You'd have to use the vanity lights an awful lot to require a new battery every year.
That seems odd, especially since you might have replaced them yourself and they might be fine. It also seems wasteful. Mandatory service is usually required to avoid subsequent issues related to failing to do it. But the worst case scenario is that you'd have the batteries go dead later on. If it's truly mandatory, then perhaps when I get to that point, I should take the batteries out, test them, and leave them out before going for service. If they're good, I can hold onto them. Otherwise I can recycle them.Yeah, it's odd. When I took our Air in for the first annual service visit, I was told visor battery replacement was a mandatory replacement item for that visit.
They replace your fob battery every time you bring it in, regardless of the charge status.That seems odd, especially since you might have replaced them yourself and they might be fine. It also seems wasteful. Mandatory service is usually required to avoid subsequent issues related to failing to do it. But the worst case scenario is that you'd have the batteries go dead later on. If it's truly mandatory, then perhaps when I get to that point, I should take the batteries out, test them, and leave them out before going for service. If they're good, I can hold onto them. Otherwise I can recycle them.
I noticed that. I had a few things noted on a due bill and a few things that needed to be attended to and made an appointment within days of getting the car. Despite having just a few hundred miles on it, they changed the battery.They replace your fob battery every time you bring it in, regardless of the charge status.
I don't see any reason not to pull the batteries out of the visors before your year-one service, if you want to recycle them or use them in another device. Lucid is likely just recycling or throwing them out, anyway.
Well they know there is a design flaw in the fob and not everyone will use batteries without the bitterant coating. Replacing it just saves CS the trouble of someone complaining about a dead fob.I noticed that. I had a few things noted on a due bill and a few things that needed to be attended to and made an appointment within days of getting the car. Despite having just a few hundred miles on it, they changed the battery.
It seems counterproductive, not only because it's wasteful but also because it gives the impression that they don't expect the battery to last very long. Also, it's not difficult to check the battery with a meter and put it back if it's within spec.
They don’t expect the battery to last very long. They expect it to last about a year, plus or minus a few months to a year.It seems counterproductive, not only because it's wasteful but also because it gives the impression that they don't expect the battery to last very long.
This. Cost of battery < Cost of CS taking a call and dealing with it.Well they know there is a design flaw in the fob and not everyone will use batteries without the bitterant coating. Replacing it just saves CS the trouble of someone complaining about a dead fob.
That’s why they replace it.
Checking it with a meter would mean forcing you to change it sometime in the next year or so before your next service.
People would complain about dead fobs. In fact, they already do. Replacing them is a trivial addition to service, and makes people happier on average, as their fobs don’t die.
Seems like a no-brainer, and the same decision I would make.
A policy is a policy. They’re cheap, and it isn’t worth not changing given even a minor risk of a CS call. They have deemed the cost of an extra battery to be less than the cost of calls from customers and/or complaints about dead fobs. The end.There's a difference between changing something proactively after six months that's expected to last a year, and changing a battery that's a few weeks old. But my car came with two fobs and short of asking people to drop off all fobs, I don't see it fixing that issue.
Yes. Usually they call their 20-30 year old kids, but sometimes they call a Handyman. ASK ME HOW I KNOW lolI wouldn't put anything past people but I'm surprised that anyone who has a dead fob wouldn't try changing the battery. Do they call a TV repairman when their remote control stops working?
Yes.I only have 5700 miles on my GT but I'm coming up on 1 year of ownership. The car, however, is about 18 months old. I've got no issues right now but I gather that the car isn't going to give me a message that annual service is due or I would have seen that already.
Is that correct? I just need to proactively schedule it?
For mobile visits, they test the voltage and if it’s 3V, they don’t replace. Then a couple months later, I had to use the app to unlock the car and input my pin to drive since it couldn’t detect the fob. Next day I used the dead fob on b pillar to unlock and replaced the battery. So I agree that just replacing the battery is an easy preventative step and good customer serviceThey replace your fob battery every time you bring it in, regardless of the charge status
Good to know. I'm getting close to 24k.Good afternoon,
I've scheduled my 24,000 mile service. Although I thought the dash on my Lucid would issue an alert that it was time for the service, it did not. Isn't the Lucid dashboard supposed to alert that maintenance is due?
Also, apparently, the 24,000 mile service requires Lucid to keep my car for 2 - 3 days due to the brake fluid replacement. When I scheduled the service, the service advisor did not mention that Lucid would keep my car overnight, let alone for up to 3 days. I called Lucid to find out how long the service would take and was advised of the lengthy maintenance time. I thought I would wait for my car and schedule other appointments in Virginia for that day since I must travel over and hour to reach the service center and believed it would be in and out within a couple of hours. If it's time for the 24,000 mile service, ask for a loaner vehicle because it's not a quick process.
