This makes sense…New owner of Air Pure 2023 AWD since April 10, 2024. No regen braking at 90 percent or above. It comes back to life below 85 percent SOC
when the car is at such a high SOC, the regen will not work well because there is no place for the recovered energy to go, the battery is already full.I just want to share my bad experience when I charged to 100% and the drove just 1 mile to my hotel. The parking lot was in the basement about 30 feet below the street level. There was a 1 foot hump from the road before descending into the parking lot. That hump is meant to prevent rain water from going into the basement. I crossed the hump and I was only going 10mph to make a 90 degree left about 100 feet away. I had almost no regen and I could not brake fast enough. I had $40k of damage (mostly the front sensors on the bumper, Lidar, bumper, air bags, steering, frunk and it took 3 months to get my car back. Good news is that the car was perfectly restored and after that I drove 11k flawless miles with some simple caution. Charge to 100% ONLY before a long distance trip and only when I know that till 95% I am on a flat road. At 95% the regen appears close to normal. For my local driving I usually charge only once a week 45% to 80% and it meets my needs. As others mentioned, Lucid does not use hydraulic brakes at 100% to simulate the same result as regen. I hope this tale of caution helps you and others prevent what happened to me.
I don’t think regen braking has anything to do with sensors. In simple layman’s terms, It’s just the same drive motor changing into a dynamo to generate energy when you let go of the accelerator. Regen is prevented and motor decoupled from drive, only if the battery cannot take anymore power from motor to store. So this can happen when the battery is full /almost full or it’s too cold outside and battery has to be warmed up sufficiently to accept the power. Basically regen is prevented as safety measure and I think there is a warning that gets displayed.Regenerative braking seems to be quite variable. My car is getting a front sensor replaced, but prior to this…definitely a noticeable change. Similarly, I have a loaner…and the braking seems to vary with no rhyme or reason.
Exactly. That is why I shared it. As @Bobby pointed out, it is the way Lucid currently does while some other EVs use hydraulic braking to simulate the same level of one pedal driving at any SoC. That can change with a software update in future assuming the Lucid hydraulic braking can also be controlled by software.when the car is at such a high SOC, the regen will not work well because there is no place for the recovered energy to go, the battery is already full.
the moral to the story is to be aware of this and drive accordingly
As I've mentioned earlier in this thread - unless it was changed recently and I haven't noticed - there is currently no indictation if regen is limited or unavailable. Which is weird, considering Tesla and other competitors have a visual indicator for it and even flash a warning.I don’t think regen braking has anything to do with sensors. In simple layman’s terms, It’s just the same drive motor changing into a dynamo to generate energy when you let go of the accelerator. Regen is prevented and motor decoupled from drive, only if the battery cannot take anymore power from motor to store. So this can happen when the battery is full /almost full or it’s too cold outside and battery has to be warmed up sufficiently to accept the power. Basically regen is prevented as safety measure and I think there is a warning that gets displayed.
hydraulic? please enlighten me, which EVs use any sort of hydraulic braking to simulate regen brakingExactly. That is why I shared it. As @Bobby pointed out, it is the way Lucid currently does while some other EVs use hydraulic braking to simulate the same level of one pedal driving at any SoC. That can change with a software update in future assuming the Lucid hydraulic braking can also be controlled by software.
agreed that tesla will indicate that regen is limited and Lucid should do the same. I wonder what the code monkees have to say ?As I've mentioned earlier in this thread - unless it was changed recently and I haven't noticed - there is currently no indictation if regen is limited or unavailable. Which is weird, considering Tesla and other competitors have a visual indicator for it and even flash a warning.
I suspect this is something you’ll see relatively soon. Seems a useful fix.agreed that tesla will indicate that regen is limited and Lucid should do the same. I wonder what the code monkees have to say ?
I don't know first hand. See other postings here. I can test my wife's ioniq 5 at 100% and see what it does and report here what I find.hydraulic? please enlighten me, which EVs use any sort of hydraulic braking to simulate regen braking
I think that you are confusing the hydraulic braking systems with regenerative braking.I don't know first hand. See other postings here. I can test my wife's ioniq 5 at 100% and see what it does and report here what I find.
I believe they are not comparable. The Hyundai group EVs (Kia, Hyundai, Genesis) use a blended brake system where the first depression of the brake pedal invokes regen (unless one turns regen off entirely) while a firmer depression invokes the friction brake. To compare, one needs to use a company that doesn't use a blended brake system such as Tesla and Lucid where using the brake pedal immediately invokes the friction brake.I don't know first hand. See other postings here. I can test my wife's ioniq 5 at 100% and see what it does and report here what I find.
I think Hari is just talking about friction brakes automatically supplementing regen when necessary to make one pedal driving feel the same regardless of temperature or state of charge. Tesla has a setting for this and I believe some other manufacturers do it as well. It sure sounds like a great feature if implemented well.I think that you are confusing the hydraulic braking systems with regenerative braking.
For what it's worth, I have standard regen and drive one-pedal all the time. My driving is almost 100 percent on city streets.No. In fact, your brakes will last much longer, because you are barely using them.
Does make sense to do a form brake (in a safe place) every now and then to get any dust and rust off the rotors. But otherwise, I always advise folks to switch to hi regen and live the one-pedal life.
That would explain why I had regen breaking at 100 percent change on my Genesis GV-60, while on my Lucid I do not.I believe they are not comparable. The Hyundai group EVs (Kia, Hyundai, Genesis) use a blended brake system where the first depression of the brake pedal invokes regen (unless one turns regen off entirely) while a firmer depression invokes the friction brake. To compare, one needs to use a company that doesn't use a blended brake system such as Tesla and Lucid where using the brake pedal immediately invokes the friction brake.
Yeah - you didn’t have regen braking. You had friction brakes that it pretended were regen so you didn’t get uncomfortable.That would explain why I had regen breaking at 100 percent change on my Genesis GV-60, while on my Lucid I do not.
Yeah it really would. Possibly number one on my list at this point. It's the only feature I'm missing that actually feels like it creates danger. Others are just creature comforts to me.Yeah - you didn’t have regen braking. You had friction brakes that it pretended were regen so you didn’t get uncomfortable.
I agree it’d be a neat and useful feature for Lucid to add.
The easier, and much more likely, feature to add is just a warning that regen is limited. I wouldn’t be surprised if we see that sooner.Yeah it really would. Possibly number one on my list at this point. It's the only feature I'm missing that actually feels like it creates danger. Others are just creature comforts to me.
But then there has to be a sign somewhere on dashboard that indicates friction braking is on? Otherwise how driver will know if it’s regen or friction braking?Yeah it really would. Possibly number one on my list at this point. It's the only feature I'm missing that actually feels like it creates danger. Others are just creature comforts to me.
