Let me clarify a few things to help you. This is also not my first EV. Different EVs have different programming for the regenerative systems. There are some that use the actual brakes to simulate regeneration so the driver has a similar experience regardless of battery charge level. Some will also allow regeneration into the upper level buffer, which is really not considered healthy for the battery. Since the Lucid does not use the physical brakes to simulate regeneration, and does not allow charging above the indicated 100%, it will not slow down as forcefully as usual when the battery is full. We are hoping they will add a warning to the dashboard to let us know, although to me it seems kind of silly… We just need to know and understand our cars!
You mentioned above that your car still regenerates after charging… That is of course true, unless you charge to 100%. To convince yourself, charge your car all the way to 100%, get up to a certain level of speed and let go of the accelerator. You will find that while it slows some due to friction and wind resistance, it doesn’t slow as quickly as usually expected due to the lack of regeneration.
