- Jan 23, 2022
- Air Dream P
- Air DE Number
- 458
Just to give you an idea of range when driving fast on a common highway, I averaged 2.6 mi/kWh from San Diego to Las Vegas driving 80mph in my DE P on 21” wheels.
thanksJust to give you an idea of range when driving fast on a common highway, I averaged 2.6 mi/kWh from San Diego to Las Vegas driving 80mph in my DE P on 21” wheels.
I would strongly recommend getting used to 1 pedal driving, it really is better; takes some time but worth it in my opinionOk.... Now this begs the question. I personally drive my vehicles the old fashioned way (two pedal driving). I think I have learned my braking technique from monitoring displays on my previous Hybrid style vehicles (Old Lincoln MKZ, and currently Volvo xc90 T8). There was a certain amount of pressure applied that would use the motor for regen. Once you were past that point, it would actually engage the "real" brakes.
What I am wondering:
While two pedal driving in the lucid, is there a visual cue much like this on the dash or anywhere to let you know you are using 100% regen, and not the brakes while braking? I am unsure if I will ever get accustomed to one pedal driving (I occasionally use the "B" regen on the Volvo, it acts like a very mild down shift, and is engaged using the shifter, so it is somewhat natural for me).
for now whatever regen mode you choose it applies to all drive modes, I would like to think that soon we will be able to have standard regen in smooth mode and strong regen in swift mode which would make sense to meThat worried me a bit before my test drive. Having never driven an EV, other than a golf cart, I did not know what to expect. I told the salesman same when we got into the car for the test drive. We started in 'Standard" and switched to Regen during the drive. It it took a little getting used to, but just a little. I was worried at first that my wife and son in the back seat might get sick as my wife does tend to get carsick, but by the second or third rolling stop it really was not an issue.
Mya current DD, a BMW 530e, does do regen but it is so mild it is hard to tell.It is funny, I've been practicing on my current car that does not do regen.![]()
Wait, SOC changes the behavior of regen? It seems consistent to me on the LucidTakes 2 min to figure out. The people who struggle doing it are the ones that feather the throttle when they drive, which has always struck me as odd. Maintain foot position on the throttle when wanting to maintain speed, when you want to break, let off. After 2 min on different regen settings you’ll know how hard it will break, also dependent on battery temp and SOC. Too full of a charge, less regen is allowed, too cold of a battery, again, less regen is allowed.
Charge your car up to 95%+, regen will be limited due to no where for power to go in the pack.Wait, SOC changes the behavior of regen? It seems consistent to me on the Lucid
Likewise when your battery is cold, charging with regen could damage it. Hence, the car will reduce regen. Probably not an issue for @hydbob in southern Cal.Charge your car up to 95%+, regen will be limited due to no where for power to go in the pack.
Ahh okay thanks for the new info!Likewise when your battery is cold, charging with regen could damage it. Hence, the car will reduce regen. Probably not an issue for @hydbob in southern Cal.
55. 19” wheels, little elevation difference at start and stop points, you should get 4.7 to 5.So anyone want to gander a guess what mi/kWh you'll get going 55 mph in 90 degree temps?
I agree. 1 pedal driving feels very intuitive. Though adjustment whenever I have to use a gas-powered car.I would strongly recommend getting used to 1 pedal driving, it really is better; takes some time but worth it in my opinion
I find that regen comes back to normal around 95%.Charged to 100% for the 1st time - experienced the much lighter than normal region until SOC got to about 85% or a bit lower, then seemed to return to normal. I thought something was wrong and I needed to call Service, but remembered the threads here which explained why. This forum is wonderful!!
Interestingly enough, my last two golf carts had regen and so I have happily introduced myself again to it with the Lucid and Tesla. After almost 3 weeks of trouble-free driving, I am thinking Christmas will be great. To @Fritto520 Keep those updates coming. Loving it!!!!That worried me a bit before my test drive. Having never driven an EV, other than a golf cart, I did not know what to expect. I told the salesman same when we got into the car for the test drive. We started in 'Standard" and switched to Regen during the drive. It it took a little getting used to, but just a little. I was worried at first that my wife and son in the back seat might get sick as my wife does tend to get carsick, but by the second or third rolling stop it really was not an issue.
Could very well have been for me as well - didn't push it.I find that regen comes back to normal around 95%.
