Pictures of wheels without aero covers/inserts?
Thanks to Mkatz for the Sept 18 post with pic of 19 inch wheels.
The black lug nuts and "lucid" center cap have to be ordered or are they just there if you remove aero cover?
Have to be ordered.
Have to be ordered.
I saw the pet dish and the car covers on the accessory web site, but no black lug nuts or LUCID cap.
i Sense I visit with my DA and order through them as delivery gets closer?
The lug nuts and silver disks are not on the website. I believe there was approximately $100 for them. You can ask your DA to have the service center install them prior to delivery.
See part numbers below:
Very late reply, but is that a matte cosmos silver?
No, it's a custom wrap:
And here we have the 19s without the inserts shod with the winter tires
What color?
Here are mine on my Dream. Note all the damage to the black portion. Heart breaking. It’s from dirt and gravel being trapped and ground into the wheels by the covers. I’m having the wheels repaired.
I am 99% sure I saw somewhere in the forum the black on the black lug nuts is actually a rubber sheath (condum?)
If I need to change the tire, that sheath needs to be removed and then placed back on? Anybody done that?
Does Lucid supply appropriate size socket wrench for removing lug nuts?
Thanks
Thanks
The lug nut covers come off fairly easily. It helps to have a tool to remove them (e.g. Set of 1 removers).
I haven't found one in my car, but the Air uses a 21mm lug nut, which is one of the three most common sizes. Also, none of the nuts have a security head on them, so you don't need a special tool for that.
Problem with removing caps on 20s is that the center hub shows and is not very attractive. Hoping someone has a solution for it. I would like to remove them as well.
Lucid has a hub cover with their logo available.
ok great. I’ll try and find it.
Here are close up picks of the 20’s with the cover removed
Yeah, I think you can use the same center cap and lug nut covers they sell for the 19s. They were supposed to be on the online store by now, but if you contact Lucid, they should be able to get you a set. I forget how much they cost.
Don't the aero inserts just pull out of the 20s like with the Dream 21s? Why did you have to remove the center cap?
