- Apr 9, 2022
- Short Hills. NJ
- GT
- T0X1NJL7
Ok, so we have the 20's, 21's - someone please post the naked 19's !!
Starting pretty good dialogue with my DA. Looks like Lucid will fly me to Phoenix from Tucson to pick up my GT when it gets here. VIN promise within 2 weeks was not true but hell, I was feeling good for a while. I also had requested the 19-inch wheel mod mentioned in this forum and received this reply:I found those inserts look very cool in motion. It look almost kind of hypnotic.![]()
So how hard is it to put on or take off the aero covers?Was hoping to see if anyone has pictures of the various wheels without the aero inserts? mainly trying to find them for the 19s/20s specifically but also curious what the other options look like without the covers/inserts
Do you have the 21" wheels? I have the 21" Aero Blade wheels .. Trying to figure out if I should remove the inserts on mine .. which should be back to me in a week.Took mine out. I wished I had done the day the car arrived as they do scratch the wheels after a few hundred miles. Went from 3.2 to 3.1 mi/kWh. Not noticeable on a long trip.
Trivial. They’re on clips.So how hard is it to put on or take off the aero covers?
Do you need to take off wheel and tire or can you pry off with screwdriver and tap back on with rubber hammer like I did hub caps on 1973 super beetle?
Aero blades don't have inserts - they're solid wheelsDo you have the 21" wheels? I have the 21" Aero Blade wheels .. Trying to figure out if I should remove the inserts on mine .. which should be back to me in a week.
Thanks.
btw, do you have before and after photos to share?
Thanks .. funny thing .. I had my Air delivered the other day and had to send it back to a service center (a bit of a story there), but did take photos of the delivery. Looking back on the photos today, I realized that even though I ordered 21" Aero Blades, the car was equipped w/ 19" Aero Range wheels .. Will make sure that the correct wheels are on when it comes back.Aero blades don't have inserts - they're solid wheels
Indeed, IF you are interested in taking out aero covers, and you have yet to have the car delivered, I'd ask them to do it before they deliver the car so you won't have the scratches (or they'll fix it). Now maybe they've improved the clips since the DE 21" wheelsTook mine out. I wished I had done the day the car arrived as they do scratch the wheels after a few hundred miles. Went from 3.2 to 3.1 mi/kWh. Not noticeable on a long trip.
Pop off but be warned there might be a lot of scratches if you haven't taken them off yetI’m going to take mine out. I like the look much better. Do they just pop off or is there a trick?
Can you explain please?Pop off but be warned there might be a lot of scratches if you haven't taken them off yet
Pop off one of your inserts and inspect your rim. All the DE21" rims have scratches on the outer edgeCan you explain please?
Not mine, since I popped mine off *at the delivery* because who needs an extra 10 miles of range?!Pop off one of your inserts and inspect your rim. All the DE21" rims have scratches on the outer edge
As a few others have mentioned, on the DE21" wheels when you pop out the aero inserts, you may find that the places the clips held the inserts in place have irreparably scratched the wheels. Have your Lucid service do it for you so that if it does scratch they'll replace the wheels. Its a known issue that does not happen all the time.I’m going to take mine out. I like the look much better. Do they just pop off or is there a trick?
To be clear, it isn’t the removing of the inserts that scratches the wheels. It’s a design flaw where with the inserts in place they loosen slightly over time and let grit/dirt in, which then ends up scratching the wheels. Removing and replacing the inserts does not, on its own, scratch the rims.As a few others have mentioned, on the DE21" wheels when you pop out the aero inserts, you may find that the places the clips held the inserts in place have irreparably scratched the wheels. Have your Lucid service do it for you so that if it does scratch they'll replace the wheels. Its a known issue that does not happen all the time.
Thanx for that clarificationTo be clear, it isn’t the removing of the inserts that scratches the wheels. It’s a design flaw where with the inserts in place they loosen slightly over time and let grit/dirt in, which then ends up scratching the wheels. Removing and replacing the inserts does not, on its own, scratch the rims.
