You probably know more than you need, but in case you missed it, the EA 350kw are only really useful when you're down below 20%. The 150kw are nearly as fast at higher SOC.
FYI, the Lucid Nav can set EA as a priority (which I found useful). Otherwise, download the ABRP, EVGO, and Chargepoint apps, and cross check with the Lucid Nav when you feel the need. The range will make it easy.
Also, download the Tidal app, get your 3 month free code from Lucid, and set up some playlists. When you connect your phone the Tidal app on Lucid will pull the playlists you created and you're good to go!
