Coltonw011
- Feb 13, 2022
- Lucid Air GT
Did you get to 2.0.12 yet?? I know you were trying to bump to 2.0.8Should be automatic once you put in a destination
Yep! On 2.0.12 and I get the turn by turn and miles upon arrival.Did you get to 2.0.12 yet?? I know you were trying to bump to 2.0.8
You know you can find it now on the pilot panel under settings, trips
Oh so do I, was just hoping you finally joined the rest of usYep! On 2.0.12 and I get the turn by turn and miles upon arrival.
Not the Mars?!The moon!
Mars is already inhabited by all the Muskites.Not the Mars?!
Yes, but it's more useful to have it constantly on display in the driver's binnacle. And there's plenty of room there with the new layout. Lucid needs to restore this very useful display.
If Lucid engineers are reading, I would prefer the mi/kWh display is optional. We're driving an EV that only cost $10 to fully charge vs $100/tank for a comparable ICE. From my screen above I'm clearly not aspiring to drive more efficiently - and don't want to try.![]()
Exactly. Trust me, when you hit cold weather, serious headwinds etc. the m/kWh comes in very handy as it can give you a pretty accurate stance on consumption. A trip you did on one full charge may take 1 or 2 charging stops in future all dependent on weather etc. As @hmp10 said, it allows you to adjust your driving by seeing that number.I relied on it more to adjust my driving if I thought that range might become an issue on a long haul. I know there is now a remaining-range function in the Nav system and that the battery charge level can be set to display range instead of percent, but I make a lot of trips without using the Nav system, and the m/kWh gives more instant feedback in terms of how one's driving is affecting range than any of the other displays.
I think the sample it is using has a lot of history in in and is not an instantaious reading.
That’s gone in the software updateView attachment 5724
The miles remaining to destination is a lot better now and actually updates in real time. Was pretty spot on in my most recent trip up and down to the bay area from LAI think the sample it is using has a lot of history in in and is not an instantaious reading. my expected range can drop 80 miles when I have only driven 60.
If we could set the sample size( say last 5 mins or based on the last hour of driving0, It would be useful enough to warrant putting it back up there
Darn I guess I have a bug then. Will call support. Thanks guys!Oh so do I, was just hoping you finally joined the rest of us![]()
I have driven about 75 miles since updating to 2.0.12 and haven't been able to activate Highway Assist. Only see ACC. Tried holding down the ACC button while on the highway but no option for highway assist. Anything I am doing wrong?
Funny, mine offered highway assist after about 6 miles.
You do have to calibrate it before it will work. It instructs you to drive for 30 minutes on a fairly straight highway.
Some people think it may have to be an interstate highway rather than a small one and you may need to be using ACC during it.
Mine calibrated after less than 5 minutes using ACC on an interstate highway. After it calibrates you get a pop-up window saying Highway Assist is now available.
weird. it's not showing up there for me.If using the navigation, the Air logo is replaced with the "next turn" nav information (on the right side of center cockpit). I'm on 2.0.12 and it's working fine.
I have the same problem. I think it's a bug.I’m on 2.0.12 and I’m still not seeing directions to next turn on the center cockpit. Is that expected? It’s on the left side of the right most cockpit screen. I still see the Air logo on right side of center screen.
