Open the frunk and you'll see it at the top left right under the hood.If needed where would you refill it?
I agree with GEWC on this. On the main highway to and from our home I encounter clumps of traffic frequently alternating with empty stretches that would cause the automatic high beams to cycle annoyingly often. On such a road I would prefer just to stay on low beams even during the brief spells of empty road. While I have activated the high beam assist in the main menu so that it will be quickly available when I want it, I don't want it to be the default setting every time I get in the car. I would much rather engage it via the stalk when I'm ready for its assistance.
In short, this new feature operates just as I would have it.
High beams are meant as a safety feature of the car. Do you only wear a seat belt when you are in a dangerous driving situation? High speed driving? In wet and/or snowy conditions? I don't think so. Law indicates you wear it all the time. Never did I say that high-beams should remain on "all the time". It is a toggle. Use it if you want, don't if you prefer not too. Maintaining a steady state in no way changes how any of us drive. I will let this one go as an "agree to disagree" and leave it up to the development team at Lucid to decide.Count me on team "no high beam". If your sight is such that you need high beams to be on all the time unless there are other cars coming at you, you probably shouldn't be driving.
High beams are meant to be an enhancement for extremely dark situations.
Amen!!!!!!Seems to me that the best implementation should be that the setting is remembered from the previous time the car was driven and based on the driver profile. So if I have auto high beam set 'on' the last time I drive the car, then it should be set to 'on' the next time I drive it. If it's different for my wife, the it should remember her setting the last time she drove it.
Your seat belt can't blind another driver headed in the other direction.High beams are meant as a safety feature of the car. Do you only wear a seat belt when you are in a dangerous driving situation? High speed driving? In wet and/or snowy conditions? I don't think so. Law indicates you wear it all the time. Never did I say that high-beams should remain on "all the time". It is a toggle. Use it if you want, don't if you prefer not too. Maintaining a steady state in no way changes how any of us drive. I will let this one go as an "agree to disagree" and leave it up to the development team at Lucid to decide.
I’m not sure if this new feature. While car is in park, I went inside to listen to music. About few minutes into the session, the screen prompt me countdown to shut down car by itself. I then stepped on the brake, the warning went away and didn’t bother me again of same warning rest of time I was in.
Good feature not to let car go to sleep and get locked in the car.
Forgive me but having high-beam assist ON would absolutely prevent on-coming drivers from being blinded. In it current state, for those that haven't upgraded that the risk is higher for oncoming traffic since you have to manually turn it off. Moreover, the way Lucid designed their headlights, they are aimed at the ground, not at oncoming drivers with their leveling technology.Your seat belt can't blind another driver headed in the other direction.
If you drive with high beams on all the time, you are endangering others. Period. No automated system is going to flick the beams off perfectly every time before the beams hit another driver.
As I said, I think Lucid is absolutely making the right call here.
Older BUGS
1) When I hit the 3D map setting on the map on the pilot panel, it displays a weird blue-ish color on top of the pilot panel that disallows the map to take over the entire screen.
Thanks. Just got and started the 2.0.12 updateOpen the frunk and you'll see it at the top left right under the hood.
Correct.
No. You just need to remove it in your app, forget the “Lucid-#####” Bluetooth device on your phone, remove the mobile key in the car, and re-add it. I’ve always done it in that order but I’m not sure it matters.
The “Lucid Air ###” Bluetooth device is for music/calls, and you don’t need to forget that or disconnect / remove the Bluetooth device in the car.
I believe that a lot of folks are missing the point.High beams are meant as a safety feature of the car. Do you only wear a seat belt when you are in a dangerous driving situation? High speed driving? In wet and/or snowy conditions? I don't think so. Law indicates you wear it all the time. Never did I say that high-beams should remain on "all the time". It is a toggle. Use it if you want, don't if you prefer not too. Maintaining a steady state in no way changes how any of us drive. I will let this one go as an "agree to disagree" and leave it up to the development team at Lucid to decide.
You will get a message on the left of the center screen saying that Highway Assist is Available.How exactly do you know that "Highway Assist" calibration is over. Is there anything that pops up on the display letting you know? Do you actually have to turn on "Dreamdrive" to find out?
I got that, I did just that instruction on screen to turn on Highway Assist. I haven’t tested on a non straight Highway yet.You will get a message on the left of the center screen saying that Highway Assist is Available.
I followed the instructions from @borski (namely, remove the phone/mobile key and added it again).My mobile key has always been spotty and only partially functional, at best The whole "car waking up as you approach it" has never worked. Always have to open the app, wait for the car to wake up, then press unlock. And every second to fourth time I get in, i have to reenter my PIN. @bhramabull and I were discussing this earlier, he has had the same issue. I have reinstalled the mobile key several times, as well as unpaired the phone and paired it again and then added the mobile key. But it just will not reliably work using my phone as a mobile key. I was hoping these updates would fix that, but so far, same issue. The people at the Scottsdale SC were not able to help. Their only suggestion was to try the same reinstallation of the mobile key process. Yes, the location sensing is always on and all of those things.
Anyone else run into this or have any suggestions?
On the passenger side when you open the frunk. I filled up the fluid, now I don’t have spray issue. I just feel spray is weaker than in the past…If needed where would you refill it?
If Lucid changes this setting and remembers the last "High beam" setting, what happens when you start driving from your house? Will you be lighting up the entire neighborhood on your way to the freeway? This is not a rhetorical question - just curious.The only thing that is missing (AND only for those that have enabled the feature) is to have it recall the last setting for the next drive.
I think the disconnect here is between what both camps think of as the reason for this feature.I believe that a lot of folks are missing the point.
If you would like to use the "High Beam Assist" feature, then enable it (by going to the Settings->Vehicle->Drive Settings menu and turning it on). If you find that you don't need to have the High Beam Assist feature, then don't enable it (i.e. turn it off).
But for those that have the High Beam Assist turned on, then activating the assist (by pushing the stalk away from you) is likely. When activated, it can be de-activated (by pressing the stalk away from you).
The only thing that is missing (AND only for those that have enabled the feature) is to have it recall the last setting for the next drive. After all, it stands to reason that if you've enabled the feature, you'd like to have it on most of the time (as I do) and only turn it off when appropriate (and then back again).
Not sure what the big fuss is .. the developers did most of the hard work (and it does work well)... As I've stated before, I'm sure it's an oversight and will be added later.
