- Nov 14, 2021
- Dream P
- Air DE Number
- 33
- R0YBCKIJ
3 years and still having the same problems. Charge point knows they just won't fix it.
I’m seeing exact same thing on my CP with a new Touring. If I switch the breaker off and on, it works. But, I have to do it every time I want to charge.I have been using ChargePoint charger as well. Occasionally, you will see a RED light on the charger for unknow reason. The only way to get around is turn off the breaker and turning it back on.
You would see the solid RED on right side of the charger as shown below
The issue is with CP. Back when the Air first debuted and people were having issues, they replaced chargers with an updated version which didn't trip the internal breaker. Now they won't do anything about it.I’m seeing exact same thing on my CP with a new Touring. If I switch the breaker off and on, it works. But, I have to do it every time I want to charge.
Ok thanks. I rent mine. Any suggestions on a replacement? …other than the Lucid?The issue is with CP. Back when the Air first debuted and people were having issues, they replaced chargers with an updated version which didn't trip the internal breaker. Now they won't do anything about it.
Call Chargepoint. And push it up the chain. Go through all their BS of resetting breakers, etc so that it'll flag in their system.Ok thanks. I rent mine. Any suggestions on a replacement? …other than the Lucid?
Yeah I left my chargepoint schedule on. It works but is a bit funky. Will probably switch to the car schedule, just hoping it has weekend vs weekday (or similar) schedule capability.Exactly, I had the same issue. Once I turned off schedule on Chargepoint app, it works.
I’ll have them come out.Call Chargepoint. And push it up the chain. Go through all their BS of resetting breakers, etc so that it'll flag in their system.
The Air generally doesn't work with externally-scheduled (charger side) charging. The car's own scheduled charging, that you set from the center screen, does work.Yeah I left my chargepoint schedule on. It works but is a bit funky. Will probably switch to the car schedule, just hoping it has weekend vs weekday (or similar) schedule capability.
If you keep turning on and off the breaker, you may cause damage and short circuit. Thats why I went back to using the Lucid cable and a plug in. Stopped using Chargepoint. They have a software issue with Lucid. Chargepoint needs to get together with Lucid engineers and figure out what the problem is. Listening Lucid? Please address this for your cutomers.I have been using ChargePoint charger as well. Occasionally, you will see a RED light on the charger for unknow reason. The only way to get around is turn off the breaker and turning it back on.
This is not true. Cutting a breaker (turning it off) does not cause a short circuit. A short circuit occurs when a hot wire accidentally touches a neutral wire or ground, creating a direct, low-resistance path for electricity, which can cause the breaker to trip. Turning off a breaker simply interrupts the flow of electricity on that circuit.If you keep turning on and off the breaker, you may cause damage and short circuit.
Lucid has nothing to do with this. This is a Chargepoint problem, and chargepoint has made it pretty clear they don't seem to care. Literally every other EVSE works fine with the Air, except Chargepoint. Moreover, Chargepoint has fixed it as mentioned by @hydbob; they just do not care enough to send the new version (which doesn't trip the internal breaker) to people who have the problem. So take up the issue with Chargepoint.Stopped using Chargepoint. They have a software issue with Lucid. Chargepoint needs to get together with Lucid engineers and figure out what the problem is. Listening Lucid? Please address this for your cutomers.
Thanks. I had the car only 24 hours then went out of town. Left the car plugged in to my existing external schedule and can see some oddities. Do you happen to know if the car schedule can vary by day or weekday vs weekend? (Which is how my utility discounts are).The Air generally doesn't work with externally-scheduled (charger side) charging. The car's own scheduled charging, that you set from the center screen, does work.
It does not. At the moment it only supports setting a start time and location (outside of which it won’t follow scheduled charging).Thanks. I had the car only 24 hours then went out of town. Left the car plugged in to my existing external schedule and can see some oddities. Do you happen to know if the car schedule can vary by day or weekday vs weekend? (Which is how my utility discounts are).
Thanks. Might next to stick with my janky experience then and just learn how it's working. Or maybe set it to fixed time of day and then override on weekends as needed - maybe that's the way to go. My discount is 9pm to 7am weekdays and all day sat / Sunday. At least if I use the car schedule I get the full regular experience.It does not. At the moment it only supports setting a start time and location (outside of which it won’t follow scheduled charging).
Yup. Also if you install Home Assistant you can get finer grained control and automations. (But I understand not everyone wants to install home assistant)Thanks. Might next to stick with my janky experience then and just learn how it's working. Or maybe set it to fixed time of day and then override on weekends as needed - maybe that's the way to go. My discount is 9pm to 7am weekdays and all day sat / Sunday. At least if I use the car schedule I get the full regular experience.
Which home assistant? I use full Google but I assume no car integration available(?).Yup. Also if you install Home Assistant you can get finer grained control and automations. (But I understand not everyone wants to install home assistant)
Seems like you might be able to get by with setting the car's charging schedule to start charging at midnight. Would that work for every day?...My discount is 9pm to 7am weekdays and all day sat / Sunday. At least if I use the car schedule I get the full regular experience.
@newlucidguy you can set up an automation in Home Assistant to wake up the car at midnight or whenever so that charger-side scheduling works reliably. I have set this up for my Air for solar PV charging, as my available charging power often cuts in and out during the day, and once it cuts out, the car goes to sleep and doesn't wake to charge again. Similar to the problem with a regular charger that uses scheduling to allow power to flow to the car only at certain times....Also if you install Home Assistant you can get finer grained control and automations. (But I understand not everyone wants to install home assistant)
Sorry, I know the name can be a little confusing. https://www.home-assistant.io/Which home assistant? I use full Google but I assume no car integration available(?).
I have a ChargePoint and been charging it since Sept 24 no issues. I’m in a 24 AT.Hi! We just brought home our new baby Lucid Air and they told us our Chargepoint home charger (which we installed to charge our previous Jaguar I-Pace and current Cadillac Lyriq ) would work just fine . . but alas. It won't charge the car. Is this just a thing? Do we need to invest in a Lucid charger now? Or does anyone have any suggestions on settings we can play with to make these things compatible? I would rather not have to get a new charger . . .as it is, the new car is already in the shop for 10 days because the Apple CarPlay and other items are all screwy. Sigh.
Thanks. I think I'm just do the daily schedule set in the car to match my utility weekday off peak times. My power is reliable and me remembering to wake up my car at midnight isn'tSeems like you might be able to get by with setting the car's charging schedule to start charging at midnight. Would that work for every day?
You can also use the phone app to trigger your car to wake up and start charging when using charger-side scheduling, if you don't mind being awake and remembering at midnight every night.
