Lucid Ham Radio Installations and Owners
2023 Air Touring
N1KE
No permanent radio equipment in the car, but portable equipment works just dandy.
It was kinda "meh" for me. Why do 5 watts when you can do 50? I tried it, but the main problem is that I had to use an MFJ antenna mount clip and a rubber duck. It just wasn't worth the inconvenience and inefficiency. Consider using my antenna setup with your HT. The feedline is 13' of RG316 with an SMA.
I would truly wonder if a Lucid Air is the right car for chasing weather. It is not going to ford standing water as your truck appears to. Snorkel or not. And I’d forget about lightening. What about hail bashing the glass and car to a bunch of dents? Sounds like the ideal car would be a well functioning beater.
No kidding! The OP's premise that EV are going to be the only option sooner than later is a bit faulty, but when someone really wants something you can create all sorts of rationalizations.
Link any existing threads here, and we can try to merge them.
I'm not aware of any thread apart from this one. The earlier thread (precursor to this one) that I started in late-Feb has become OBE so it can just sit there untouched. If you can setup the ham radio category that'd be great.
@Joe @hydbob can we make a category? Or should we just rename this thread?
Suggested title pending other opinions. “ Ham Radio Installations”. (The storm chaser aspect isn’t needed in the title.)
I really appreciate you guys doing this. And I’ll monitor it closely to help on queries.
BORSKI: Suggest we call it LUCID HAMS, since some folks might be hams but have not installed equipment in their cars.
What are the steps to get this going, whatever we call it?
I really don't care what we call it. Just be advised not to expect any substantive ham radio discussions that are not related to installing ham radio equipment in Lucid vehicles. There are beaucoup other forums out there that are ham radio specific, and that's where one would find ham radio discussions. That's why I had proposed “Ham Radio Installations” as the title. If we just call it "Lucid Hams", then we should also have categories for "Lucid Boaters", Lucid Hang Gliders", "Lucid Line Dancers"........
Most Storm Chasers understand thunderstorm structure and dynamics and therefore can avoid the hail cores.
That's fine. Lucid hams without installations can comment, and we can get their call letters.
Borski - What are the steps to get this going, whatever we call it?
For now I’ve changed the thread title. I don’t know how many folks there are, but it would have to be @Joe or @hydbob if a category were made
Thanks a bunch. I'll be monitoring it closely because I think I'm the only owner do far who has figured out how to do the installation.
BTW, is it possible to move this thread over to the new category?
Installation is not that hard. It was easy to run and hide a thick (for the 10A current) 12V cable from the trunk to the front.
Steve K2PBO
Steve K2PBO
I didn't need to run a power cable. I just put the FTM-500 TR unit in the RH trunk cubby, right next to the 12v outlet. It was just simpler for me. '
So I guess this means that two of us have installed radios in our Airs. :)
73.... Frank / WA3NHK
The trunk mount would have worked well also, but I had other needs for the 12V up front, and did not want to run speaker and conrol cables to the rear. Instead, I had to run 12V and antenna to the rear.
Just a quick FYI to the followers of this thread. Thanks to Borski we now have a dedicated owners forum category for Lucid owners who are also Amateur radio operators interested in installing radio equipment in their Lucid vehicle. Although not a moderator, going forward I'll monitor this closely for anyone looking for advice since my recent installation worked out quite well.. ( Yaesu FTM-500)
https://lucidowners.com/forums/lucid-hams.136/
