- May 2, 2022
- Philadelphia, Pennsylvania
- 2022 Air GT
- Air DE Number
- 0
I'm noticing the drywall in the garage is 5/8 (fire/sound/strength). This wall is 6" and shared with dining room. I was kinda bummed the way he installed the panel (shitty and upside-down) inside the wall. He removed all the insulation and tossed the piece he cut out. I undid his work and stuffed fiberglass all around and behind the panel to fill the voids, taped and spackeled. It still looks shitty because he didn't even bother to flush-mount the box...I should have told him I wanted a surface mount...
So I'm thinking I'm uninstalling everything...going remove the box, build 2x4 mounting studs for the 4-hole mount, re-insulate the wall, re-install 5/8 drywall, and have the electrician come and do a proper inspected connection for the Lucid (whatever it's called) thingie.
I expect that will take 6 or 8 months.
I"m wondering: Is it allowed to substitute 5/8 plywood for drywall just where Betty gets mounted...that would make it easier to get a clean conduit into the back of Betty from behind the wall. My question is does this meet fire safety codes for garages? I know there is a
burn through thingie. Should I just screw the plywood on top of the drywall ?
How would it work if I left the sub-panel (I would re-install it correctly), pulled the 50 amp breaker in the sub panel for the Juice Box and install a100 amp breaker, then feed from that to Betty ? There would be a 100 amp breaker on the main panel and another one in the garage sub-panel? Does it make sense just to skip all this bother and go directly to Betty from the main panel?
I thought I was being wise to have a sub panel in the garage to future proof, but now I'm not so sure I need it.
