AIR.LUCID
- Nov 22, 2021
- El Dorado Hills, CA
- ‘04 Prius, ‘98 MB SLK230
Has anyone heard about the eventual cost or ETA of the Lucid Connected Home Charging Station?
You will definitely need an automatic transfer switch. It prevents current from leaving you panel, traveling along the power line and electrocuting any linemen working one the impact power line.I got this information last week. The wall charger is $1,200, but it's rated for up to 100 amps (hard-wired of course). It can be wired for 50 amps with a NEMA 14-50 plug. The unit is bi-directional. I have no clue on how this is enabled, but I'll bet it will require additional hardware, like a transfer switch of some kind. It won't be as simple as installing a ChargePoint+ or JuiceBox which are not bi-directional.
I am envious!I figured as much. We haven't had a power outage in over a decade, so I think I'm going to go with a ChargePoint charger and keep it simple.
Yea seriously, where do you live? Lol Cheyenne mountain!?!?!I figured as much. We haven't had a power outage in over a decade, so I think I'm going to go with a ChargePoint charger and keep it simple.
I’ve not had one this month… 5th June … not bad for silicon valleyYea seriously, where do you live? Lol Cheyenne mountain!?!?!
A month is normal, that guy said a decade!I’ve not had one this month… 5th June … not bad for silicon valley
A power outage every month is normal? I think we've had 3 in the 5 years in our current house, with the most recent being uneventful due to our power walls.A month is normal, that guy said a decade!
Living in AZ, on coop electrical and only had 2 outages in 16 years. Last one uneventful due to Powerwalls.A power outage every month is normal? I think we've had 3 in the 5 years in our current house, with the most recent being uneventful due to our power walls.
Yes, people need to know that cords are heavy and don’t like to be put in with a lot of torque or tension.One thing to consider: a charging station (EVSE) that can handle 100 amps will have a cable close to the diameter and weight of a garden hose. A less-powerful but still capable 50amp station like the Chargepoint Home Flex will have a cable that is much less cumbersome, especially if the charging station is located at the rear of the car (from reworking a Tesla charging setup for example) and you have to drape the cable along most of the car's length to reach the front charge port.
Get a longer cord that you think you need. Better to have some extra slack.
And my advice is to put them near the garage door opening. In case you want to park you car outside and charge it still.
For the Lucid you won't have to reverse into the garage. The charging port is on the driver front fender.I like the logic - but hate reversing into the garage... plus it means I need to do a LOT of clearing up !!
maybe a job for the kids during their summer break
