Lucid Air's Number One Software Issue?
I know that. But how does a virgin phone not made by lucid get to open the car? By what mechanism does , it acquire the needed security key? For example:
A - Does it use its BLE to communicate with the cars's BLE or
B - Does it use its cell transmitter to call Lucid central and Lucid central radios back to open the car?
Thanks
BLE to the car plus API requests to Lucid's cloud to authorize it.
Thanks much. If that is correct, it leads to several thoughts:
The API rquests to Lucid's cloud are a likely source of delay.
If the non lucid phone ues BLE to the car, it must have some security token it got from somewhere when the lucid ap was first set up. If that is correct, then another device (say a new keyfob with buttons) could also acquire such a security token. If that is correct, a new keyfob is possible, without changing anything in the car and without reducing any security that now exists via the phone ap.
Oh, no, to be clear the cloud is only involved for pairing, not for unlocking. Doesn't explain the delay when unlocking at all. And yes, it would absolutely be possible to create a new keyfob. The thought has crossed my mind.
Thanks. I'm still curious about how the phone acquires the security token, and if another device can be designed by another vendor (with a lttle API help from Lucid) to acquire it in the same way.
I would imagine it's done like any other public-key cryptographic process. An initial handshake is done, each device has or generates a private/public keypair (effectively a couple really long passwords), then gives the other it's public key.
Then any future communications is encrypted with the other devices public key so that only that device can read it, and signed by each devices private key so the other device can validate that the message came from the device it claims to the be.
Thanks: Then we should be able to have the following service with Lucid's OK: Send you fob to lucid or the manufacturer and pay a resaonable fee. The manufacturer or Lucid return the original Fob PLUS a new fob with buttons. Voila
Perhaps, but I don't think lack of buttons is really the core issue with the fobs.
It's the receivers in the car. Not enough of them, or a poor choice of antenna placement.
I agree with Lucken on the occasional loss of internet and its impact on audio,
in my personal case the number 1 issue is their POOR implementation of all things bluetooth…from the keys to the profiles to the entertainment to carplay etecetra. bluetooth is grade school level tech hopefully the gravity people have refined that (crossing fingers).
I love hearing people say things like this because it makes it very clear they have never tried to implement a full Bluetooth stack (and if you have, I'm sorry for my assumption, but respectfully, I completely disagree). Bluetooth sucks. UWB is better, but bluetooth, like time zones and people's names, always sucks.
One factor is Bluetooth is on the 2.4GHz band, and WiFi on that band is many times more powerful - so Bluetooth packets can only get through in the gaps between Wifi transmissions. Also the short wavelength (~10cm) means the RF bounces and refracts all over the place, often resulting in small dead spots where devices fail to communicate (and the dead spots move about as the environment changes, i.e. people moving around).
As a result, getting anything through relies on lots of error handling. It's also not helped by lying user interfaces telling you a device is connected when snooping packets manifestly shows its not (looking at you, Apple).
Bluetooth can be pretty reliable - in RF-quiet environments. Low data rate stuff with error handlng/repeat transmissions often works by getting through during periods when there happen to be few interfering signals. Trying to use BT for relatively high rate date (e.g. audio) with lots of nearby wireless access points is always going to be hit and miss.
As an interesting experiment, take a connected bluetooth speaker and put it in a microwave oven (without turning it on, and if there is any question of it being on, unplug it). You will find that the bluetooth connection is nearly instantly broken by the shielding when the door is closed.
Bluetooth also has to put up with leaky microwave ovens, in addition to other users of the 2.4GHz band.
Bluetooth sucks. Period.
To be clear, this is why I wish the keyfob used RF, and not bluetooth.
Because Bluetooth sucks.
Bluetooth sucking is not Lucid's fault, because as mentioned earlier, Bluetooth always sucks.
Choosing Bluetooth as their technology of choice for the keyfob? Yes, that is Lucid's fault.
And before anyone tells me their AirPods work fine, most Apple devices including AirPods support Bluetooth Class 1, which have a 40 times higher maximum transmit power than the more common Class 2.
From the Air manual:
Component: Bluetooth® Vehicle Key
- Manufacturer: Pektron Group Ltd
- Model: A-0820G01
- Operating Frequency: 2402-2480 MHz
- FCC ID/ISED ID: AQO013/IC: 10176A-013
- Maximum Transmit Power: 2402 – 2480 MHz: ≤ 1.36 mW EIRP
Component: Access Control Module BTLE/LF Node
- Model: A-0819G13,A-0819G16
- Operating Frequency: 125 KHz, 2402-2480 MHz
- FCC ID/ISED ID: AQO012/IC: 10176A-012
- Maximum Transmit Power: 125kHz: ≤ 0.0057mW EIRP, 2402 – 2480 MHz: ≤ 1.35 mWEIRP
From the Gravity manual:
Component: Keyfob
  • Manufacturer: Marquardt GmbH
  • Model: UK1
  • Operating Frequency:
    UWB: 5-9 GHz
    NFC: 13.56 MHz (passive tag)
    BLE: 2.4 GHZ
  • FCC ID: IYZUK1
    IC: 2701A-UK1
  • Maximum Transmit Power: UWB: ≤ -41.3 dB/MHz
    BLE: ≤-1 dBm
Component: UWB/BT Anchor MQD
  • Model: MUB1
  • Operating Frequency: UWB: 5-9 GHz, BLE: 2.4 GHz
  • FCC ID: IYZMUB1
    IC: 2701A-MUB1
  • Maximum Transmit Power: UWB: ≤ -40 dBm/ 0.001 mW
    BLE: ≤ -3.19dBm / 0.48mW
  • Model: MU3
  • Operating Frequency: 5-9 GHz
  • FCC ID: YZMU3
    IC: 2701A-MU3
  • Maximum Transmit Power: ≤ -40 dBm/ 0.001 mW
Unusual buggy failures, warnings and faults aside, what do you think is the most pervasive day-to-day software frustration experienced by Lucid Air owners? I think it is the mobile app's inability to efficiently auto open the doors. Before anyone goes nuts, I know there are work-arounds such as carrying the fob and pushing in the door handles, but I want the ease and elegance of just using my phone. If only auto open worked as beautifully when you approach the car as auto close does when you walk away. It's not the end of the world. It never leaves me stranded. It just is the one thing that frustrates me daily, embarrasses me occasionally, and seems to be something that one really competent software engineer should be able to fix in a fairly short time. That's my number one. For me, waiting interminably for Android Auto pales in significance. Maybe I'm alone in this opinion. What tops your list?
I feel your pain. These tech bugs for simple tasks are extremely frustrating. If completely takes away from the driving experience. I just posted something similar but at the core it’s a software fix/update.
My biggest software complaints are with the audio system. On start-up it is always on and always at the "audio home" menu. I'd prefer both would stay where they were on shutdown, especially the menu. Also the SiriusXM menu take several layers to get to Favorites, put Favorites in the home SXM menu. But that might be a SXM thing. (And yeah, I know I'm old school relying using SXM - don't give me grief over it.....).
Same. I had a Tesla for 7 years and my wife now owns a Y. Both worked perfectly in terms of unlocking. My Air unlocks when I enter my laundry room inside the house off the garage. It unlocks when I'm 25 feet away walking up my driveway. When I'm at a store or away from my house though it basically never opens when I walk up to it with my phone. It's terrible!
Wow. My topic got hijacked with the very first response. 🙂
Anddddddd its gone...
I don't use Sirius nor Spotify but I do use Tidal, Bluetooth (VLC on phone) and FM -- and for all three of those, whenever I get in the car, I just hit the Pause/Play button on the steering wheel, and the car resumes whatever I was last listening too, no menus no nothin'. Have you tried with with SiriusXM?
