1. Live view should have no limitations. I need to see what is around the car regardless of whether the car is on LTE or wi-fi.
It’s in beta. It is clearly not intended to only work on one or the other, hence why it’s in beta.
2. … I need and want to see what is behind me all the time, at a glance and I can't. …
Isn’t that what the rear view mirror is for? But okay, I know you’re not the only one who seems to want this.
3. … I also want to display different types of mapping choices, such as a visual turn-by-turn. Instead, I get an aerial view looking down at the car traveling on the map but I can't see the upcoming turns. All that I see in the other window is the words describing the upcoming turns. Not what I want.
You can change the view. Click the route icon on the UI. Each tap will switch views. This is explained in the manual. They can be separate.
Touch the icon in the lower right of the map to select from one of four default map viewing modes:
- 3D Track-Up: Shows a 3D view that tracks your vehicle’s current position and rotates the map to show what is in front of the vehicle.
- 2D Track-Up: Shows a 2D view that tracks your vehicle’s current position and rotates the map to show what is in front of the vehicle.
- North-Up: Shows a 2D view where North is always at the top of the map.
- Route Overview: Shows a 2D view that displays your current route end-to-end, and North is always at the top of the map.
NOTE: The Route Overview mode will only appear when a route is selected.
The default map views will be ignored once you start manually interacting with the map. The system will maintain your personal user mode until you select one of the default views listed above.
4. Climate control: I haven't figured out how to pull just outside cooler air in. Read the owners manual. It didn't explain how to do so.
From the manual:
5. Homelink: It takes pushing the screen three times to get that to open the door. First, there is the homeland icon up at the top of the clearview cockpit windown. I should just be able to push that and it works. Instead, it then gives a plus (+) sign with my garage door listed. I then have to push that, twice, to get it to open. It should simply be geofenced to open at a predetermined distance from my garage, say 20 feet etc.
It was an option; they removed it because it was buggy. It will be back.
6. Maps - the blue line indicating route covers up anything else underneath. Also, switch to Google Maps. It’s the industry standard, they've worked out the kinks, and its' simply state of the art. Here maps is junk. It's wonky, doesn't route properly and often can't make up its mind where it wants to send you. It can't be trusted.
Lots of manufacturers use HERE. Lots of threads on this. YMMV.
7. Folding the mirrors. It should be a simple one button press to get the mirrors to fold when approaching a drive through window. Instead, it’s a multi button search to find the thing. That should be front and center and always available, at least in the left hand area of the clearview cockpit. Also, geofence that too, just like Tesla. It should know when I approach the same restaurant's drive through speaker and window, to fold the mirrors.
Swipe down from the top of the pilot panel, tap fold mirrors. One swipe, one tap.
8. The app doesn't work for heating the car. It doesn't work for driving the car. The app needs serious work.
App works fine. If you’re having issues, please be more specific. Our Gravity wakes up almost immediately now.
9. Our phones must act as a mobile key. That needs to be taken care of in short order.
Yup. I agree. It’s coming.
10. I want the ability to have the 360 degree overhead view at any time, anywhere on either display.
You already said that, re: camera views, but okay. This is very unlikely to happen, but sure.
11. The nagging has gotten really old, really quick. Most are annoying.
What nagging? If it’s the distracted/drowsy driver nagging, turn those off in settings, until they have a facial scan setup.
12. Where are the active matrix headlights? They're there, but don't work.
Be more specific. They work fine.
13. Halo secure as the ability to be as good or better than Tesla's Sentry. It needs to record anyone coming near the car as 'events'.
It’s in beta. They’ll add more over time.
14. Must have a dash cam implementation. It's a necessity.
This exists? Not real-time, but you can hit the record button for halo secure at any time and it will record the last 30s and the next 30s.
15. There should be ohter 'favorites' displayed; like 'cottage', "school", etc. Two just doesn't cut it (home and work).
You can add favorites, just not label them. I agree this would be nice.
Yeah, they specifically don’t have this for some reason. It exists on Air, so I don’t know why not here, but it seems to be for some actual reason, not a lack of ability to build it.
17. Pin to access glovebox
I’d say these two are basically the same, but agreed.
