What's driving condition there like weather and terrain (hills for example)? What's your regenerative braking setting at? Driving habits like if accelerating fast frequently?I have been driving The Lucid GT for almost 4 months now. I am only getting about 250-280 miles with 100% charged battery. Does anyone here has the same issue?
I live in Los Angeles, the weather temperature in LA is between 65-90 F. The regenerative braking system setting is high, driving mode is standard. My driving habit is normal, I did have a couple of joy ride acceleration, but most of time is normal. I even turned off the music, AC, massage to increase the mileage, but it didn't help much. I took the car to service department for testing and no faulty were found.
The car has about 3600 miles on it now, I drive about 80% local, 20% highway.
Thanks for the advice, I will try that out.I would take a 20 mile continuous highway trip , with the trip reset, and see what you get, just for that particular outing.
I wonder if local driving in LA is what is causing your low efficiency.
I have found that a lot of stop and go can be brutal on efficiency, as moving this heavy car from a full stop can eat m/ kWh.
When I am driving in a more continuous steady manner, it does extremely well.
Please post a picture of your pilot panel on the trip computer page.I have been driving The Lucid GT for almost 4 months now. I am only getting about 250-280 miles with 100% charged battery. Does anyone here has the same issue?
When the car is parked at home. Are you utilizing the mobile key? Are the fobs stored far enough away from the car or in a faraday pouch? Sadly these things wake the car with relative ease, thus keeping the car awake to drain the battery. As far as driving to keep range at its best, are you driving in smooth mode? If not, do so. Accelerate slowly off the line as well. You already have finished your AC usage as well as the massage functions (don’t worry about music). Did you use a fast charger or L2 (home charger) before posting that photo of your pilot panel? Fast chargers always chew up range unless you’ve driven sufficiently far enough to cool the pack passively so the BMS doesn’t actively have to. One of the biggest things working against you are your 21” wheels. I have 19” with a lifetime average of 4.1 mi/kWh over 8200 miles. Recently it’s been worse due to the cold (into the 30s in the morning) where my current charge has yielded 3.4 mi/kWh. I drive in smooth, use the heat seaters and steering wheel unless it’s uncomfortable and then I use the resistance heat. Rarely do I exceed 75 mph and mostly drive about 65 for my local driving.I didn't take the car to the track or go crazy with the car. Especially, I am studying the lost mileage. I have tried everything possible way to boost up the battery efficiency for maximum range output.
Standard driving mode would be Smooth, is that what you are using? Driving habit is normal. Normal for you. Which could be stomping on the go pedal and waiting until the last second to take your foot off the go pedal to slow down. Or people might be tailgating you because you drive 5 mph below the speed limit. You really didn't tell us anything.driving mode is standard. My driving habit is normal,
