- Nov 14, 2021
- Dream P
- DE Number
- 33
- R0YBCKIJ
I can definitely get 400 miles of range in my DEP with 21" wheels, all it takes is me keeping the speedo at 70 mph. I've tested this on a back to back trip over 350 miles before.Kyle, from Out of Spec Studios, used my Lucid Air GT with 19" wheels and in near ideal highway driving conditions at 70 miles per hour, he got 435.5 miles of range, He was able to pull 109 kwh from the battery. He switched to the 21" wheels, did a shorter highway run and noted 13-14% range penalty. This means my car in ideal highway driving at 70 miles per hour with 21" wheels should go about 377 miles. At higher speeds, and/or with more stop and go will dramatically change the range. As an example, right before software update 2.0.15 (where you could readily see miles per kwh since the last charge), I was averaging around 2.7 miles per kwh during a mixed use test with some performance driving. Average that out with my car on a full charge would put the range at just under 300 miles. What doesn't make sense to me is the reported range difference between a Dream Edition Range (520 miles) and the GT (516 miles). The DE has a 118kwh battery versus the GT's 112, so why does it supposedly only have a 4 mile range difference? It should be closer to a 28 mile range difference based on Lucid's calculated miles per kwh. In some ways this may help explain why some reviewers got about 500 miles of range on the DE, but I haven't seen the same for the GT (at 70 miles per hour). Bottom line: I'm not convinced the GT is a 500 mile car at true highway speeds with the 19" wheels. I also suspect it will be hard for a GT with 21" wheels to see 400 miles at true highway speeds. If you drive at a steady 55 miles per hour (below what I consider a true highway speed), the advertised range numbers might be achievable, but we haven't tested that. Of course, your range will vary, and I'm basing my analysis on Kyle's thorough testing of my car and my own testing as well.
