You can, and should, just leave it plugged in....is there something different about a 240 charger where I can't just leave it plugged into the wall like I can the 120?
If you must use a receptacle, I'd spend the extra money on the correct Hubbell or Cooper. There are several Amazon comments that this item is not as good as it should be. But I wouldn't install a receptacle for EV charging at all. Ever.Speaking of highly-rated 50 A outlets, does anyone have a Journeyman-Pro outlet that is billed as EV-compatible?
I went to a hubbel after my Home depot outlet meltedOne last point from Brother @DeaneG. I also generally agree against the use of receptacles for continuous use high amperage applications, I.e. EV charging, but if you are going to do it,be damn sure you are doing it spot on: proper size copper conductors, proper size HD wall box, newish proper size breaker, use the best receptacle you can get and torque the receptacle lugs TWICE to specs. And don't constantly pull out and plug in the charging cord.
Professional installation, the receptacle wasn't cycled with hundred of connects and disconnects; and zero issues as should be expected! The key here is the professional installation.
Leviton builds many high quality receptacles for the industry with different specification grades just as Hubbell, and Legrand does; know your use and needs, and use the specification that meets your needs and you will have years of trouble free use.
ELECTRICAL FUNDAMENTALSJANUARY/FEBRUARY 2005
Receptacle Grades: What Do They Mean?
iaeimagazine.org
I hope not.Speaking of highly-rated 50 A outlets, does anyone have a Journeyman-Pro outlet that is billed as EV-compatible?
OMG, @Electrified , I love the article on receptacle grades. 2005, well before EVs.I hope not.
And quite frankly not much has changed since then, open a project spec book and what you see below is standard receptacle specs for commercial and institutional space. Google 5362 with any of those manufacturers name below and you will see a 20 amp 120 V receptacle , Hubbell and Leviton call it there industrial grade while P&S calls it there hard use Spec Grade.OMG, @Electrified , I love the article on receptacle grades. 2005, well before EVs.
The two edged sword of HD Lowes and Amazon. Any numpty (English term) can easily buy parts that if improperly installed, can burn down their home or kill them. Those same numpties leave bad reviews on Amazon for great devices because the part does not have DIY LCD simplistic instructions. Or bitch because their boob of a handyman screwed up the install.
Since I jumped the gun and ordered the Journeyman PRO from Amazon before posting here, after reading the replies I also ordered a Bryant and decided to compare their designs. The Journeyman came as a pleasant surprise - very sturdily built, the plug fits nicely, and I didn't have to get a different faceplate to replace my run-of-the-mill Leviton. The Bryant didn't feel or look much better. So, I took a chance and installed the Journeyman. The results, so far at least, are good - with the Leviton the plug used to get quite warm, if not hot. With the Journeyman, the charger body is warmer than the plug. The charging speed is marginally higher than before. The Chinese must have improved their design, since some early Amazon comments claim that the charger plug wouldn't even go into the outlet all the way. Just my 5 cents.Run away, do not walk.
Listen to my brother from a different mother. It's a no-name Chinese copy of the Hubbell and not even a direct copy. Notice the receptacle diameter is 2.15 inches on this Chinesium while the truly industrial plugs are 2.45. So, Wang Chung is taking the same molds as the $10 Levitons, and adding hex lugs. Lip stick on a pig.
Notice it's sold by ONE Chinese import shop in Washington state with other cheap Chinese imports, and not by any REAL electrical suppliers. Risking an electrical fire on saving ten or 15 bucks? This knock-off is the type of screw the unsuspecting consumer product Amazon does best: you just know the margin on this four times a Hubbell.
Remember, the UL rating is not the issue. The $10 Levitons are fully and properly UL rated and are just fine for stoves, dryers and welders. Nothing wrong with them for Intermittent use!!
Despite the name, I can assure you that no licensed journeyman would touch this crap.
Gotta love how the Chinese name shit, trying to imply a licensed and bonded electrician would use this. If a Chinese product has PRO in the name, you can be damn sure it's not.
That is what I do. I only had a plug installed in case I needed/wanted to change out the EVSE without calling an electrician.I've always charged my cars over 120. I never needed anything faster, even in the before times when we commuted every day. Since the charger included with the Lucid comes with the adapter for 240 (which I'm assuming is this 14-50 thing) I'm planning to hire someone to install the appropriate outlet. I'll be sure to get a recommended outlet and avoid the Leviton. That being said, in the 7 years I've owned EVs, I've unplugged the charger cable from the wall maybe six to ten times, including the times a charger was unplugged to return a leased vehicle. I unplug my dryer to clean behind it, fix it, or replace it just as often. is there something different about a 240 charger where I can't just leave it plugged into the wall like I can the 120?
You did the right thing. Those smaller cover plates and boxes are made for the lightweight residential outlet, which won't stand up over time.I thought I'd thought of everything. But while the Electrican brought a Bryant receptacle, he did not bring a matching cover plate. The (standard) metal plate he had was too small. I visited Ace and Lowe's before landing at Grainger where they had a plate which is slightly too big. And then the electrician concluded the box he'd put in wasn't quite right so he went to get another. All is well that ends well. We can now add 37-43 miles per hour and I did check to see the prongs aren't warm when I unplug from the outlet (which I won't typically do).
If it is a 14-30 receptacle (read the letters molded in or look at the prongs in this photo), you can buy this item from Lucid to use with your Lucid portable charging adapter: It's not just a plug adapter - some components inside tell your Lucid charging adapter to pull only 24 amps from the receptacle instead of the 40 amps it would pull if plugged into a 14-50 receptacle.My brother in law has a 30A Leviton outlet he was excited to let me plug into outside. I only have the 50 portable plug. Question, if I had the 30 adapter, would this still be a concern of the brand?
