Gravity Delivery Discussion
ugh well that makes me feel bad as I guess there's something "wrong" with my DE. Hope they can fix it quickly; maybe they ran out of modules when building these things?
The module was in mine they just needed to push a software update to the car (version still remains 3.2.0 after it’s performed). It was done by a service technician though so not sure if it’s OTA doable or has to be booked in.
FWIW, my Gravity came equipped with Homelink already. Good thing is it spans across profiles!
(So does Air’s Homelink; they fixed this many updates ago in 2.4
“All your programmed Homelink devices can now be used by all the profiles associated with your vehicle. You may have to reprogram your Homelink devices in case you do not see it in the updated list.”)
My second key fob and "Homelink installation" are on a due bill.
Saw the blueish wispy artifact from the HUD. Definitely a sun interaction of some sort. It was not affected when I tried polarized sunglasses--though the HUD itself disappeared with the sunglasses.
Replying to myself...
My wife, Tonya, had a test drive in the GGT from 1-2pm today. Weather was overcast with light sprinkles.
She saw the blue wispy HUD artifact. For her, sun angle didn't seem to change it--but the sun was higher in the sky and it was overcast.
Also, turning off the HUD had no effect.
However, she found that shifting her eye position higher (raising her seat) would change the size or make it go away completely. So it seems to be dependent, at least partially, on the viewer's position.
The HUD reflection will get you eventually, it all depends on the sun angle and car position. Sometimes, you see little and some times a lot. Yes, if I just shift or tilt my head, reflection will be not visible. But this seems to be a design problem, which I’m surprised they have not caught during the hot Arizona suns. Non of my other cars with HUDs have this issue. It seems to be reflecting off the coating of the glass that covers the HUD opening.
-iThinkEV-
Have any of the folks who have their Gravity had any issues or tried charging at networks other than Tesla? I ask bc the Tesla app is the only major app that has the Gravity listed as an option to add your vehicle. EA, ChargePoint, EVGo and few others, even ABRP (not charging app but still popular for EV routing) does not have the car available yet to add. I am curious if for networks without plug n charge or payment thru Lucid and it's app could cause issues when the Gravity plugs in and the station does not recognize the vehicle and doesn't charge or is unable to use discount rate plans.
