Was so taken by the size difference between the Air and Gravity I neglected to mention something they added to the work order for my Gravity when I dropped it off: "Driver Side Hush Panel". The note says it's a recall campaign, and reads:
"The driver's side hush panel may interfere with the brake pedal, preventing it from fully returning to its resting position. This can result in the brake system remaining partially engaged, leading to a reduction in power."
I'm not even sure what the heck a "hush panel" is, and how it might impede brake travel. The name implies it's an affordance for quietness in that area of the car. Anyone know for sure?
They're the panels on the bottom side of the dashboard usually used to provide sound insulation from the AC or other stuff inside the dash itself.
