- Mar 7, 2020
- Naples, FL
- Air DE-P, 2 Gravity DEs
- Air DE Number
- 395
- Gravity DE Number
- 067
238
- 033M4EXG
I assume you've reset/set the preferred units in your profile and so forth.
Yes I did that when we reset the profiles during the mobile tech visit. My partner is Polish, so we set his profile to metric displays and mine to Imperial displays. The displays of speed, temperature, and range all track accordingly for each profile. It's only the posted speed limit display that doesn't. (We did have an earlier problem with the temperature on the front and second-row screens flipping spontaneously between C and F, but that problem disappeared along the way with one of the resets done for something else.)
I'm guessing they re-pushed 3.2.2 and you've done a factory reset . . .
I'm not sure. The mobile tech tried to fix the frozen nav location problem be repushing one of the software program modules. However, that didn't work and he had to get on the phone with someone from the HQ software team. After a few minutes I left them to it, and the tech remained in the car on his laptop while talking to the software team for a considerable time. When I came back to the car, the mobile tech said they were opening a case on the issue and had to get someone from the ADAS team involved. He then said they might have to reflash or replace the ACU but would not make a decision until the case investigation proceeded further. As of yesterday, he's had no response back.
