The charger I posted about is literally the exact opposite of this. Interstate in a rural area.EA only limits the charging on non-interstate urban chargers. That said I would never charge above 80% its too painful.
A possible solution is additional fees for beyond 85%. Like idle fees. Call them what you want. Road trip fees, congestion fees, inconsiderate of others fee.
EA could also utilize a location based virtual queue. If there are say 5 cars in the virtual queue and you are reading your book oblivious to the world at 85%, make the rate absurd like $5 per kW. $10 per if there are 10 cars waiting…
Come to think of it, they can barely get PnC to work well so that might be like year 2035 tech for them….
So you haven’t done a road trip on a holiday period then? All those 6 station locations on the interstates are full with lines of 10+ cars most of the time. Larger sites are definitely needed.Most of the areas people need to charge to a high SOC are remote. I'd rather have 10 6-stall stations than 1 60-stall station.
I’m sitting at one now. But your point is valid.EA can’t even keep the chargers operational let alone be able to provide a reservation system through the app. The fact they still only deploy sites of 4 to 6 chargers only is ridiculous and helps contribute to the backlog of cars waiting.
People can shit on Tesla all they like but at least they’ve got multiple sites of 20,40,60,100 chargers. Show me an EA or EVGo site with 20+ chargers. They’re almost non-existent
Yeah they all look like they fall into that example of “metro” areas. With the exception of the one in Pennsylvania that I pictured and is listed. The Sheetz (gas station/connivence store/made to order food) only exists because of the interchange between two major highways. And is far from urban.in urban areas where DC fast charging is more accessible with other stations nearby. Locations along highway corridors are not part of our Congestion Reduction Pilot to ensure EV drivers can get enough charge to make it to their destination.
Hypothetically, if it takes 80 minutes for a level 2 charger at 11 kW to add x amount of charge to a battery, would a DCFC at 44 kW add the same amount of charge in 80/4= 20 minutes?
Probably a lot more complicated, but I just want to have a rough estimate.
Thanks, Neil.The DCFC will likely be slightly faster. For level 2 charging, there is a voltage boost and AC to DC conversion. The losses are between 10% and 15% for energy into the battery. There are no conversion losses for DCFC but still some resistive losses for current into the battery. 44kW is slow enough that it may not require battery cooling depending on the ambient air temperature and how the battery was preconditioned. Hence, my conclusion of slightly faster for DCFC.
Same here. I’m wondering if their rates will allow for subscription plans / discounts, as with other EA Accounts.
I got the email, but they show my free charging ending in Feb instead of June. Hopefully I still have free charging until then, not that I use it often.
