Dead charger
Paulk
2022 Grand Touring
4 day old LAGT…factory demo…two nights ago it blew the 59 amp circuit breakers.. the next morning after resetting the breakers, the car refuses to charge and displays an errot. Car was picked up in a covered flat bed truck from Santa Rosa to go to Millbrae. We are not happy! $90k spent and it cant make it a week ? WTF
I’m not sure what you mean by “59 amp circuit breakers”. That’s not a thing.
What EVSE did you use? What does the wiring look like for the circuit?
My Lucid has never popped my breakers.
Hold judgement until you know the reason.
I am also confused by your post. The machine hanging on the wall is an EVSE and delivers the power to the car but is not the charger. The charger is actually inside the car. As noted, there is no such thing as a 59 amp breaker. Assuming you meant 60 amps, then your EVSE can deliver 48 amps to the car since the amperage delivery is at 80% of capacity. Is/was your EVSE set to deliver no more than 48 amps?
What error was displayed?
So...did your EVSE break or is it the car's charger?
I would recommend that you not jump to conclusions. Modern cars, like the Lucid Air, have been described as smart phones on wheels. While that is not completely true, there is a lot of electronic technology in your car and electronic stuff tends to fail early or not at all. You may just be the victim of the early fail and other than updates, your car may never go back to the service center.
Yes.
Yes, is a 240/ 50 amp outlet. The cable being used is the one from the trunk. Car was verified by L that the cable and its connections are fine. Prob is IN the car. TBD as to cause. Hope we get her home soon. Just filled up w high test gas.. a lot of under the breath cussing
Want my Sunshine burner back…
Yes.
Got it. It does sound like a failure in the car. I've heard of only one or two similar instances of this particular issue in the two years I've been on the forum. Hope yours gets repaired soon!
Was typo from old guy..was 50 amp breakers. They picked up my LGT in a covered flat bed. And returned her same way. The problem was a defective Wonderbox. Other symptoms were inability to change driver profiles, add garage door openers. Dont know why they all were present, but car is back with 450 miles available. We will try to charge after we burn off some sunshine power. Man, what a gorgeous car. The tow truck driver warned us about the 21” wheels and to avoid pot holes! Wife driving now..its for her. We are retiring her MBZ S550 or her SL550. She has always been a MBZ gal. At the new car moment, she loves the LGT!
I am glad the service took care of the problem. Enjoy the car!
I can’t get past the fact that you paid only $90K. I’m glad your car is fixed now though.
