- Jul 7, 2022
Exactly.Possibly ignorant question, but I have breezed through this thread and still wondering how you guys now your charging rate has dropped. Is it just by checking the app from time to time?
Yes, that's how I have checked it. I'm picking up my Gravity tomorrow from the service center where they checked the rate decrease based on screenshots I sent them. This was part of some other work they performed. Here is what they said:
Job: 12 Charging ProductsPay Type: WarrantyConcern: Customer states that when charging on Level 2 chargers, the vehicle displays a rate reduction and the charging kW decreases. Photos havebeen attached as needed. Please check and advise.Cause: Can not verify abnormal charging operation.Corrections: Vehicle came in with SOC 68%.Tested vehicle charging - vehicle is charging as designed.Scanned and reviewed fault memory - no related DTCs found.Customer's 1st pictures shows a charging rate of 13kW with 1 hour and 5 minuets of charging left before set limit of 80% achieved.2Nd picture shows the rate slowed down to 11kW with 25 minuets of charging left before set limit of 80% achieved.EV charging automatically slows down as the battery approaches its set limit to protect battery health. This "tapering" prosses is managed by the"Tapering" when approaching the end of charging session is a normal charging function.Technician IDs: 018692Labor Description Action Total PriceHV Electrical General Diagnosis HV Electrical General Diagnosis Diagnostic 0.0Note: I actually charged it at the service center 80A J1772 charger while waiting for my ride, so the decrease in charge rate and my screenshot were taken at the dealership. I had the maximum set to 80%.
P.S. I think this is
I agree the explanation is not correct. The car will not tapper the level 2 charge until the SOC is in the high 90% range.Yes, that's how I have checked it. I'm picking up my Gravity tomorrow from the service center where they checked the rate decrease based on screenshots I sent them. This was part of some other work they performed. Here is what they said:
P.S. I think this is a bullshit explanation
It’s also just untrue; mine does not taper.Exactly.
I'll check when I pick up my car and see if the charger is the old -1 model. I think these chargers are the same J1772 ones from 4+ years ago, which may explain the throttling, although it doesn't help me much on my NACS charger, since it appears they still only have -1 model versions of these.It’s also just untrue; mine does not taper.
I think the newer Lucid branded chargers are the only ones that aren’t doing this.In three charging sessions with my newly installed V3 (J1772) LCHC I have yet to catch my charging rate to drop off.
I believe that is correct, which is why I added my data point to the discussion.I think the newer Lucid branded chargers are the only ones that aren’t doing this.
How can you tell the version?My replacement charger is soon to ship out, and I will work to get the new one installed and ship the old one back to Lucid. Hopefully the v3 version solves the issue for me as well, but yeah, this is clearly a software issue with at least all other EVSE. I don’t really ever use any other chargers to add a data point, but maybe I’ll try the charger at my condo (208v/50A) next time I need to charge to see if that exhibits the same issue, I just don’t love paying 3x the cost of electricity to charge on equipment that was paid for as part of a special assessment.
The model will end in -01, -02, or -03.How can you tell the version?
I've got one in a box in my garage since ~November that I haven't gotten around to installing. If it's not V3 I wonder if Lucid would exchange if there are concerns about performance for V1 and V2....
I have four NACS chargers, and they all end -0. Only one of them is installed right now and it has the problem. Or should I say the car has the problem, because my GEN-1 Tesla charger also has this issue.I've got the NACS charger (which isn't installed yet). The SKU is P21-Y04401-00. Are these having the problem too?
