My 2017 chevy Bolt does a better jobRemaining range at low SOC is always an estimate in any EV.. Some companies hide the imprecision by providing a larger bottom buffer.
Cool. Enjoy it in good health.My 2017 chevy Bolt does a better job
It’s worth having service check battery diagnostics to make sure nothing is wrong. They can check that quickly.I went from 5% to 1% overnight after a 7.5 hour drive. Was the conclusion from this thread that it should be brought up to customer service?
Considering it myself since this is the first time even at very low states of charge this has occurred.
SOC estimation error accumulate as you drive and recharge. 7.5 hours is not that long of a drive but it depends on how you were driving and how many times you had to recharge. AS Borski says, ask service to take a look.I went from 5% to 1% overnight after a 7.5 hour drive. Was the conclusion from this thread that it should be brought up to customer service?
No, not often. But when I get on a long drive, there are circumstances when I'd rather go eat than sit at another charger for 30-45 minutes.It is mind blowing to me that someone would run the car down so low so often. I'm not criticizing, it is your car to do what you want with it. But I would never run my ICE car down to the last 32oz of gas and expect an accurate reading from my "distance remaining" instrumentation. JMHO YMMV.
Lucid looked at the cell balancing and determined either BMS/battery is faulty, so. Awaiting what steps come next.It’s worth having service check battery diagnostics to make sure nothing is wrong. They can check that quickly.
If diagnostics show the battery is fine, this is likely due to the fact that low SOC estimations are immensely difficult to make accurately.
Makes sense. Hope they fix it quickly for you.Lucid looked at the cell balancing and determined either BMS/battery is faulty, so. Awaiting what steps come next.
AwesomeLucid looked at the cell balancing and determined either BMS/battery is faulty, so. Awaiting what steps come next.
You all can sit down now
Not to steal the thread but if Lucid used a refurbished battery, it might make sense for you to check if it meets this capacity threshold from the Lucid OEM warranty:I think ChatGPT is correct. I recently had a very similar experience with my AGT. Noticed that my range had suddenly diminished from where it normally was, especially when I was at a low SOC. . I explained to my SC that it was as if electrons were "leaking out of my battery". Indeed, when they checked it, cells were out of balance. They replaced my entire battery with a refurbished one. Problem was solved.
They didn’t. They use a remanufactured battery.Not to steal the thread but if Lucid used a refurbished battery, it might make sense for you to check if it meets this capacity threshold from the Lucid OEM warranty:
"If it is determined that your battery requires warranty repair, Lucid will repair, replace, or adjust the part with a new, reconditioned, or remanufactured part at the discretion of Lucid. However, Lucid will ensure that the capacity of the battery will be equal or greater than the original battery capacity during the warranty claim."
To me, refurbished means you have a reconditioned battery.
Please read the rest of the thread.I just had this happen! Yesterday, I had 85miles of range. Went to grab breakfast 35 miles on the dot round trip.
Get home with 50 miles of range...Check, Spot on!
Didn't go anywhere yesterday because it was raining cats and dogs, but in the 60s temp wise.
This morning i get up and was like "ah crap i forgot to plug it in, but ehh i got 50 miles left to get get breakfast"
Open up my app 13miles left!! WTF! it was in the 50s all night so it wasn't a cold issue. Anyway, Breakfast was 12 miles round trip, made it back with 1 miles remaining and now it's charging, but what the actual F happened to 37 miles of range?
Was a bad cell.Just stumbled across this thread. Not sure if its still an issue but a bad cell could indeed explain the issue. A battery pack consist of thousands of cells. When a cell is around 4.25V its considered full (100%) while its considered empty somewhere around 2.7V to 3V (0%) depending on the chosen bottom buffer. Anyway, the issue with SoC state estimation is that the decline from 100% to 0% is not linear. Which makes accurate SoC estimations complex - to the point that it cannot be measured accurately but to some degree has to be guessed.
Now the problem: if there's one bad cell amongst the thousands, then the discharge characteristic of this one cell changes. Often this becomes especially apparent at a lower SoC. Bad cells tend increase their internal resistance disproportionally when they're no longer under load, or when the battery pack's temperature change. Thus making the estimation even more difficult. So when you park your car and the pack cools down, this could be a logical consequence in case of a bad cell.
Long story short: my money is on a bad cell.
If you happen to have a bad cell.Was a bad cell.
...Essentially, 1/5 of your battery is entirely untrustworthy and that's ok![]()
Nobody knew I had a bad cell when recommending and suggesting hahaIf you happen to have a bad cell.
I'd say more like 10%. Which, yeah, the gauge in an ICE vehicle is also a wild guess below that level as fuel sloshes around and expands and contracts with temperature and air pressure. I drove 10+ miles on a fully "empty" tank in my 2015 Mercedes, but it just as easily could have gone the other way. Same with EVs. There's a Lucid range test video on youtube where the gauge said 0% and the driver kept going for miles.But....don't let your car get below 20% ever and don't trust anything below 20% is the advice from this forum. Essentially, 1/5 of your battery is entirely untrustworthy and that's ok![]()
