- Jan 4, 2022
- Santa Clarita, CA
- 2023 Lucid Air GT
- AWNJLGKT
Coming 08/31/25 @ 11:59PMLet me guess, last week of August...
143 days until August 31 2025Let me guess, last week of August...
Interestingly, Tesla is using MapBox also.
2026.. Its 143 + 365143 days until August 31 2025
OrderedJust ordered... Almost 6 years of quotes to help carry the torch
Is this different from licensing from HERE? Or Mapbox? Any vendor could raise their fees....All it takes is for Google to up its licensing fees and Lucid has no choice but to pay once they're all in....
HERE generally works OK for me when I am navigating to a place that has an address, though all it can do it bring you to the parking lot entrance, not the building entrance, as it doesn't have that data....I'm in the "I wish Lucid used Google Maps as the native mapping app" camp. Not that any nav logic is anywhere close to perfect, but I've only had my AT for a couple of weeks and I've already seen a few routing errors with the native app where I live. The native app is good enough I suppose. I guess it's a cost saving measure on Lucid's part.
Is it possible to show where you connected your dongle and also where you keep it. Sorry...I like to be spoon fed.Hi all. I got AA working using the dongle below that I ordered from Amazon.
I did not like the fact that it was not scaling on cockpit LCD, so I let it go. Tried Car Play and saw that was cutting the side of the LCD screen to create a rectangular area, no good either.
You can update this data. I’ve done it for a a number of locations and they work great now. You can also add side streets, easements, etc.though all it can do it bring you to the parking lot entrance, not the building entrance, as it doesn't have that data.
It's a lot easier to replace one portion of your system if someone decides to screw you over vs having to replace multiple elements of it. Cost probably plays a big role in it also, At a high level, these companies charge every time you make an API call, Google has increased its costs by 1400% over time where HERE has made costs more attractive allowing more API calls for cheaper but there are other reasons why HERE is chosen over Google when it comes to assisted driving systems also.Is this different from licensing from HERE? Or Mapbox? Any vendor could raise their fees.
There's only one USB port in the car, at the far end center of center console closer to the center glove box. The dongle has a short USB cable and thus will have to sit inside the center console close to the USB port. Once plugged, follow the Bluetooth connectivity instructions that come with the dongle. You'll have to connect your phone to the Lucid_id device that is advertised by the dongle. Good luck.Is it possible to show where you connected your dongle and also where you keep it. Sorry...I like to be spoon fed.![]()
(There are two ports there; one USB-A and one USB-C)There's only one USB port in the car, at the far end center of center console closer to the center glove box. The dongle has a short USB cable and thus will have to sit inside the center console close to the USB port. Once plugged, follow the Bluetooth connectivity instructions that come with the dongle. You'll have to connect your phone to the Lucid_id device that is advertised by the dongle. Good luck.
I have it hooked into the USB-C port.Is it possible to show where you connected your dongle and also where you keep it. Sorry...I like to be spoon fed.![]()
Yes. The car only has one USB-A port, and the device I was using connected thru USB-A port.(There are two ports there; one USB-A and one USB-C)
You are using a different model than what I was using. How does yours scale the LCD cockpit? The same problem I had or it scales full screen with no problems. If so, do you mind dropping in a pointer to the device or its manufacturer and model number? THanks.I have it hooked into the USB-C port.
I'm using this: https://www.amazon.com/dp/B0CMXHMGZ8?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1 It scales to the screen in my car, not overrunning the edges of the cockpit screen.You are using a different model than what I was using. How does yours scale the LCD cockpit? The same problem I had or it scales full screen with no problems. If so, do you mind dropping in a pointer to the device or its manufacturer and model number? THanks.
What's your source on that guarantee?I can guarantee you that Lucid did not wait 2-1/2 years to submit to Google. I understand the frustration and wish it would be released but it is not that Lucid has been waiting to submit.
Conversations with people on the software team.What's your source on that guarantee?
So, was the "can confirm AA is coming this fall" in June 2024 mean that was the initial submittal?Conversations with people on the software team.
