I have a machine shop I’ve used in the past that has a CAD/CAM program for my projects. Let’s hope they made it through CovidDid you use Vcarve for this project?
Sounds very promising.I have a machine shop I’ve used in the past that has a CAD/CAM program for my projects. Let’s hope they made it through Covid
Count me in to buy your dead pedal 👍My usual supplier of rubber strips no longer carries any thing that is considered hard rubber in the appropriate size, it’s all spongy. I have then got sidetracked with work and a bunch of nuisance things( both central air at home and office went south, painting the house, etc) so I’m looking at other companies to supply the hard strips in fits and starts. It will take a bit longer than I anticipated as life got in the way
👍I’m in
👍I’ve had this idea rolling around in my head to get an aluminum and rubber dead pedal replacement machined for the cheap plastic piece that currently serves that function. Basically the idea is to take 3/16 or 1/4 stock aluminum and mill out using a CAD/CAM program the lucid logo and the dark areas on the template about 1/2 way into the stock. Then insert and glue rubber strips into that groove that would rise above the aluminum about 1/4 inch. The logo I would fill with grey epoxy or if I wanted to get fancy use some 3M self adhesive open faced walnut to match my interior to be just under level into the letters. Before assembly I would probably do a little sandblast of the aluminum to give it the soft burnished look of the aluminum in the interior. I would also radius the foot just a bit where it kicks out. For attachment I think the exposed metal areas underneath would work for some sheet Velcro cut to size and would be about as thick as the existing carpet. Any thoughts on the design or is anyone interested if I get some pricing I may make more than one, certainly cheaper to run a small batch. This is just a rough concept at this point
You may be on your way to becoming one of the first third-party aftermarket mods suppliers for Lucid owners, if you're not careful.Well it looks like a big initial batch ( lower overall cost greater numbers I hope)
I wonder if anyone has trademarked “Air Accessories “You may be on your way to becoming one of the first third-party aftermarket mods suppliers for Lucid owners, if you're not careful.
"Air Supply"?I wonder if anyone has trademarked “Air Accessories “
LOL, excellent idea. There is no such thing as bad publicity!"Air Supply"?
You can get the band to sue you; the free publicity will be well worth it.
Since it’s for foot accessory, might as well call it Air Jordan.LOL, excellent idea. There is no such thing as bad publicity!
I have the car, let me know when you want the money 👍I wonder if anyone has trademarked “Air Accessories “
