- Dec 17, 2021
- Greenville, SC
- Sapphire 1 of 6
The 21s are 265 rear and 245 front. I believe the 19s are 245 all the way around. Someone with 19s can correct me if that is wrong.Not to worry, I can see where you're coming from with that assumption though!
EDIT: I should mention; handling characteristics definitely improve if the tire is wider, since there's more surface area gripping the road, but as far as I'm aware, the width of all the wheels is the same and it's just the diameter of the wheel that is different. As the wheel size increases, the sidewall of the tire decreases.
