- Mar 7, 2020
- Naples, FL
- Model S Plaid, Odyssey
- DE Number
- 154
- 033M4EXG
New Languages
You can now set French (Canada) or Spanish (Mexico) as your system language. These new lanague settings apply to both your displays and Navigation
Key Fob
You can now open your trunk with your key fob.
To open the trunk, short press the key fob once, then long press again. If you are within range, the trunk will open. You can also close the trunk using the same short-then long-press combination.
Traffic Sign Recognition
We’ve enhanced your vehicle’s ability ot identify traffic signs, including those in Canada. Your vehicle notifices you when it recognizes certain traffic signs, keeping you informed of speed limit changes and other important road information.
Navigation
In this update, we’ve made sweeping improvements to our Navigation app, released highly anticipated enhancements and improvements for a smoother Navigation experience.
Offline Navigation Mode
We care about your privacy, which is why we’ve Introduced Offline Mode. In Offline Mode, you can use GPS to navigate while your vehicle is otherwise not connected to any cellular or Wi-Fi networks.
To enter Offline moe, go to Navigation settings -> Offline Mode and turn the toggle On.
Offline maps are required to navigate in Offline Mode. To download maps you need, to go Navigation Settings > Offline Maps > Download Maps, then select the maps you want to download. The regions of the maps you have already downloaded will appear under Downloaded Maps. We’ve also added the ability to pause and resume specific map downloads, giving you more control over how many maps you are downloading at once.
More Interactive Map
We’ve also added features to make the map more interactive. You can now tap a point of interest or stop along your route to view information about it, and where available, pictures and ratings from TripAdvisor. If you search a particular area for a type of destination, you can now pan in or out and search again in the new map area by tapping Search This Area. If you are unable to find a specific point of interest or destination, you can now tap any location on the map and the app will route you to it.
Improved Range Estimates & Routes
We’ve improved how we calculate estaimted range to rimpveo routes between charging stations. We’ve also added battery charge details to more places in the UI, so they are easier to find, and Navigation will propose up to 3 optimized routes so you can choose the best one for you.
To help you find EA charging stations more easily, Nav will now default to searching just for EA charging stations. You can disable this setting to add all charging stations to your search results.
Nav will now remember a route in progress if you take a break. When you turn your vehicle back on, the active route will automatically appear on your displays. Nav will also remember your recent searches so you no longer have to re-type a destination you just searched for.
Finally, all routes will now display traffic information, so you can plan accordingly.
Other Navigation Updates
We’ve updated Nav to include the exit number and destination in both turn-y-turn guidance and the directions list.
Nav now features lane guidance on the right side of the Glass Cockpit, so you can anticipate which lane to be in before making a turn.
If you’ve changed your map view during your route, it will no longer return ot the default view until you tap Recent or switch Map Modes
We’ve added the option to sort and filter charging stations according to your preferences. You can now filter by distance, power output, plug type, and more.
We’ve added the ability to manually remove and change the order of planned stops to customize your route.
We’ve added realistic 3-D landmarks to maps.
Other Minor Updates
We’ve enabled HiFi streaming in TIDAL for higher quality audio experience when you have an eligble TIDAL account
We’ve improved fan operation for a more comfortable climate control experience
Other minor updates, improvements, and fixes
Except for the lack of a satellite map (which I sorely miss), this will put the Lucid nav system pretty much on par with that in our Tesla Plaid and remove the niggles I've had with Lucid's nav. If all the updates perform as intended, this is GREAT news for our upcoming road trip.
Thanks for this detailed information.
