Mobile key question
Leafnut
2022 Lucid Air GT
Air DE Number
0
So the mobile key is spotty and some have it worse than others. Regardless, it's a known problem to access entry to our cars. It's unacceptable for a car of this quality to have entry problems.
My questions are: is Lucid actively trying to fix it? Is this a hardware issue that is unsolvable via updates.and will require retrofit parts? Has Lucid made any statements regarding a potential fix for earlier models?
While I love the car, I'm always amazed that when I walk through my garage to do something other than drive my Air, the car unlocks without fail. However, the amount of times it doesn't work as I've stood at my driver's door trying to open it is downright sadistic. How does Lucid know my intentions? 😂
From what I've read, it's a hardware/patent licensing issue. Highly unlikely that Lucid will do any sort of retrofitting to existing cars.
I'm hopeful for the future since it would seem they've adopted a more traditional system in the Gravity. Maybe they'll change out the system in a future MY.
Many of us here have been asking for a statement for months, if not years. A statement is needed because people trying to be helpful post all kinds of "fixes" that don't work (turn of wi-fi, wrap the fob in aluminum foil, walk to the back, jiggle then try again). Helping to rid us of time-wasting anecdotes would seem only reasonable.
They have done so.
That's good and thank you. Can you help us find the statement from Lucid?
I stood right next to Peter Rawlinson when he himself discussed this situation publicly. As I've said here before, he divulged that they were locked into a vendor deal for this key and unlocking system and they were also disappointed with the performance. Unfortunately, they do not currently have a way out of it. Now, I'm no lawyer, and I didn't vet the information or even past judgment on it. I'm just passing along what I personally heard him say.
I have also personally spoken with several Lucid executives who are also very aware of this situation and want to change it. But, it is currently not changeable.
If the contract is tied to the life of the model then maybe the Lucid Aero can be launched. Looks very similar to the Air in almost every way but in this model the key just magically works for some reason :p
Understood and thank you very much.
While we live with this, can we still expect a statement that helps us by stating, for example, wrapping the fob in aluminum foil or any other faraday cage, turning off wi-fi, trying to open rear doors first, will not make unlocking the doors more user-friendly.
I've been a major griper over this issue and now that I finally understand that it's a contract problem, I, for one, am gong to drop it. But, a statement about the useless work-arounds would still be welcome.
..I've been a major griper over this issue and now that I finally understand that it's a contract problem, I, for one, am gong to drop it. But, a statement about the useless work-arounds would still be welcome.
Only a small percentage of Lucid owners would ever be aware of such a statement, and it would have a short lifetime. Also, Lucid can't issue continually statements about every new hare-brained "workaround".
This forum, as a proxy for Lucid owners in general, has a new batch of "this is unacceptable" owner complaints every two weeks or so. Often a statement is demanded from Lucid management (here in the forum again, usually not from Lucid). Then each new user figures out a mode that works for them, and move on.
The contract and and seeming gag oder must come from the key manufacturer Pektron. I wrote to them once, but got no answer. A group effort might help.
After reading waaay too many posts about this, I am under the impression that the best path is to use either the FOB or the mobile key, but not both. Is this generally correct (but not 100% applicable)?
Right! My own path has been to use one for a few months, then the other, to see which works out better for my use case.
My verdict: the fob is more reliable (for me), but the mobile key is more convenient. FWIW I used mobile key on my Model 3 but don't remember it much.
With the fob, I can leave passive lock and unlock turned on.
With the mobile key, I have to turn off passive unlock or the car will be constantly jittery when I'm working in the garage.
For me, it's Mobile Key all the time and I bring the fob if I'm going to use a valet. I wish that they had some sort of geofencing to turn off passive unlocking in the garage (like other cars).
