Jiggling the key FOB
L-Dude
Supporting Member
SE US
2025 Air Grand Touring
KYSLYZ47
I've tried getting an answer to this in various threads without luck, so I thought I'd ask directly here. Occasionally, my Air GT fails to unlock as I approach. When this happens, I jiggle the key FOB in my pocket and the car unlocks immediately. This works 100% of the time. My question is: Why does this work? (FWIW I do not have mobile key set up.)
I’m adding this to my techniques. Thanks!
Because the key is probably asleep to preserve battery and shaking it wakes it up.
That was what I was thinking, but I wasn't sure the FOB had a sleep mode.
My Model X is usually pretty good...but sometimes it balks. Its fob is often in the same front pocket as my phone and it seems to have problems if the fob is hiding behind the phone. Might be something similar here.
When my fob is a little slow, depressing the door handle manually when I arrive at it also always opens the door.
This seems to usually work with the phone in my pocket as well, though I haven’t tested it as thoroughly.
The battery in your key fob may have a loose connection. I've replaced mine many times now and it is not a very secure connection. Jiggling it may make the connection.
