Charging At Home Question
navman
I have aTesla Model S which I charge at home using a 40amp circuit, get around 30 miles an hour, good for overnight charge.
Ordered a brand new 25 Air Touring yesterday and have a few questions, all advise would be greatly appreciated.
  1. Can I use the same charger for Lucid?
  2. How quick will the charge be?
  3. Do new Lucids have cable included?
  4. Is any free charging included?
When you say you charge at home using a 40amp circuit, do you mean you have a Tesla home charger connected to that circuit or you plug the Tesla directly into the wall?
I think Lucid's no longer come with a charging cable. I bought one that sits in the trunk and has never been used. https://store.lucidmotors.com/40a-mobile-charging-cable-kit/
For home charging I have a ChargePoint charger -- this one: https://www.amazon.com/dp/B07WXZDHGV?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_10&th=1 that works great for both my Lucid and my BMW i4.
Lucid also sells a home charger. https://store.lucidmotors.com/lucid-connected-home-charging-station/
1. You didn’t mention which charger you have. Does your charger have J1772 or do you have an adapter for that? If so it should be fine.
2. You’ll certainly still be fine for an overnight charge. I don’t know which version of the S you have to compare specs, but I would expect the “miles/minute” to be similar if not a little higher for the Air.
3. No, I don’t believe the mobile charger is included anymore. You can get one from the Lucid store online, but any from a reputable brand will do.
4. This keeps changing, but I don’t think so. Last year they switched to giving a charging credit instead, which you could put towards one of Lucid’s chargers. Ask at delivery or check your contract, because you may be able to choose.
I assume you have a Tesla charger...
You'll need a NACS to CCS Adapter
Charging at 40 amps will also roughly give about 30 miles/hour -
I don't believe the new Airs come with a mobile charger or free charging but ask your service advisor, you may get an incentive towards a.mobile or home charger. As others have stated, other brand chargers work well. If you really want a Lucid charger there are many listing for new chargers at a discount on this forum by private parties.
OP would need a NACS to J1772 adapter for home AC charging. A NACS to CCS adapter would only be useful for DC fast charging, at a later date.
1 &2. If you have the tesla charger, you will need a NACS-J1772 adapter. I use that set-up and get about 34 mph. It should also work at Tesla Destination chargers. The Lectron version costs about $120. Note that this is different from the Vortex NACS Fast charging adapter which is for Tesla Superchargers.
I purchased my Air Touring recently, it didn't come with a charger or free charging, but it came with a $650 credit for charging accessories, which, coincides with how much they charge for the Lucid portable charger. That charger runs at 40 Amps, but the electricians on the board say that you shouldn't charge at more than 80% of your circuits capacity, so if you have a 40A circuit that could cause problems. If you have a 50 Amp circuit, it's good for about 45 mph.
I am using a regular wall charger outlet similar to Dryers (see image)
Ordered my AT last week and am also waiting for it to arrive. For my order:
  • Do new Lucids have cable included? Wasn't included, but I believe I'm entitled to a $650 rebate on either the mobile charging cable (which costs $650) or the Lucid charger, which is roughly double that price.
  • Is any free charging included? I was told this promotion is over. No more free charging at EA.
Good luck on your Lucid as well!
Which adapter will I need to connect Tesla cable to Lucid?
My bad, thanks for catching and correcting. It got me thinking though... would the NACS to CCS work for the home setup too? Since the Air will be able to charge at Tesla SCS soon, it would be easier and cheaper to only buy one instead of two.🤔
Oh and a link to the NACS to J1772 adapter for your Tesla charger -
Might want to wait for @DeaneG to answer before buying ...
If you have the tesla charger, you will need a NACS-J1772 adapter. I own one from A2Z EV. It roughly $90. I think Tesla makes a Universal home charger that can be used with J1772 cars.
It's level 2, so speed will be the same (in kW). The only difference is the size of the battery. Air Touring has a 92 kWh battery pack. Not sure about Tesla S
If you are talking about mobile charger (level 1 or 2), it is not included, but available for purchase. It's $650 MSRP. Since you bought brand new, the day after the delivery, you will get an email from Lucid with a coupon code worth $650 available towards the purchase of either the Lucid home charger, or the Lucid mobile charger, which essentially makes the Lucid mobile charger free.
Not anymore.
This one from A2Z looks very good, though I haven't tried it personally.
It's less expensive than the 80A TeslaTap that I and many others have used. Based on my experience, it was OK, but if I were to buy again I'd try the one from A2Z.
A2Z is a well-respected vendor for these kind of devices and the unit meets CE safety requirements (UL pending). Avoid cheapies you find on Amazon.
@DeaneG , will the NACS to CCS converter work for the home Tesla charger too?
No. NACS to CCS is only useful for DC fast charging at a Supercharger, when this capability is turned on - presumably later this year. It will not work at all for Level 2 AC charging.
For now you'd want only the NACS to J1772 adapter to charge your Air at home using an existing Tesla charging setup, or a Tesla destination charger at a hotel.
I now my Lucid Air and tested with the adapter, charges to approx 36-38 miles per hour.
I have the $600 credit from Lucid, trying ot figure out if I should use this to get a Lucid charge cable or the charging station. Couple of questions regarding this:
1. What size amp circuit is required to support charging station
2. What charging speeds will I get?
3. Can I use existing charger (see image) and use that connectivity to upgrade circuit to use Charging station?
thanks
1. 100
2. Up to 80 mi/hr
3 I don't see an image. Unless your existing charger is an 80 Amp EVSE, you'll likely need to upgrade your breaker and wiring.
Edit: Sorry, you mean the picture of the outlet in post #7? Can't tell from the picture but as noted above, you need the 100amp breaker and appropriate wiring to install the Lucid hone EVSE
How safe are these chargers at full capacity? I had a contractor advise against installing,
I was advised that the high current is a risk for the panel and may cause fire.
If installed on a proper-sized line with a proper-sized breaker and to manufacturer specs, it is very safe.
If installed by your grandpa, your house is probably burning down.
-Yes, you can use the same charger, just buy an adapter rated for 50 amps (a little more than yours).
-it will also charge at 32 amps or 7.7 kwh or about 30 miles an hour
- not sure if they do. They should. If it does not, then buy the new cable which will allow you to charge other cars from your Lucid also.
- I think all free charging stopped. Remember, for most of us this is a small benefit as we normally charge at home.
Enjoy the car!
