Low Tire Pressure Warning but pressure looks okay.
Shorisha
2025 Lucid Air
Wife is driving to work and 2025 Lucid Air is giving a low tire pressure warning but the psi looks good. The weather right now is very cold. Got down to 13 degrees and is currently 21 degrees. Should we disregard?
A 4 psi drop is normal when it's that cold.
It's too low for the 19" A/S tires = should be 49 psi.
You need to add air to all the tires.
Cold tire pressure means: "...not driven for at least 6 hrs. and not in the sun."
Expect it to go back up after driving ~20 min. but I'd still add air and then check it again when the temps. go back up.
Over-inflating a few psi is not so bad. Under-inflated tires are bad.
According to my owners manual, 45psi is the correct pressure
What does the sticker on your door jamb say? What size wheels do you have?
Don't go off of the UI, check the tires manually. Mine show this every year when it gets cold but when I add air it goes away.
Its possible that its actually a little less than 45 psi, but this UI is just rounding up. As the other 3 tires are at 45 psi, but not highlighted, they may just be slightly higher than 45.
for the 19"s i also believe the ideal psi is 49, but you expect variation day to day, temp to temp. i'd try and correct when convenient.
Change units. Also 49 is recommended for AS 19 inch
It's generally recommended to check your tire pressure monthly and adjust as necessary to keep optimal pressure as the ambient temperature changes.
