RESOLVED Touring drivers side rear door will NOT OPEN.
My rear driver door was stuck last night. Handle presented itself but wouldn't open from inside or out. Didn't see this thread so I didn't do the pull inside trigger hard. Unlocked fine this morning.
I would get service to replace that handle...
I had my driver door handle mechanism replaced within 2 weeks of delivery. Worked ever since. The Tech did say it was a known problem. The fix took 15mins.
Same issue for me too!
The driver side door will not open when approaching the car with the fob. The door handle starts fluttering like the wings of an injured bird!
I tried closing and opening with the Fob. No luck.
Luckily the other three doors were open. I got in through the passanger door. Then unlocked the driver side door using the inside handle. It opened.
I drove home. Called customer service. Waiting to hear from them!
Scary if the inside handles and the other doors also malfunctioned! Stuck some where and then wait!!
I will try to update this when it is resolved!
RKW
RKW
The same issue for me too. It happened this morning. I called the Customer Care and was told the Service Center is closed today (President Day).
4 months into the ownership of AGT, it randomly occurred twice, both on the front passenger door.
I was able to open the door from the inside on both occasions.
Can't tell if it's an early symptom of door opening mechanism falling apart or I closed the door waaaaaay too soft at this point.
Probably will eventually need a new mechanism.
